T5 CONVERSION QUESTION
Old Jan 10, 2012 | 07:49 PM
tjmat's Avatar
tjmat
Default T5 CONVERSION QUESTION
Hello everyone I've got a 65 mustang with a 302 and a T10 sideloader and I
want to change it over to a T5. Ive got pretty much everything to install
except for the bellhousing. I want to use the housing off of a 5.0 but I haven't
gotten it because i wasn't sure if i would have to change the clutch and
flywheel. I know that the flywheel is 28oz on mine verses 50 on the latemodel
,and the pressure plate bolt patterns are different. Would I have to source a
28oz flywheel with the 5.0 pressure plate bolt pattern? or could i just use my
existing clutch and flywheel but just change the clutch release lever? I
would really appreciate the input.
Old Jan 10, 2012 | 10:27 PM
1slow67's Avatar
1slow67
ROTM Moderator
You just change the bellhousing and clutch release lever.
Are you going with a cable or hydraulic setup? Or keeping the original clutch fork and using a conversion?
Old Jan 11, 2012 | 09:50 AM
TexasAxMan's Avatar
TexasAxMan
If you're keeping the stock z-bar setup, all you'll need is a spacer block to attach the release lever.
Old Jan 11, 2012 | 03:27 PM
2+2GT's Avatar
2+2GT
True- with the correct T5 spacer block, the release lever you have will do the job.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
