fitting some wide wheels in the back...
Old Jan 24, 2012 | 10:02 AM
69mach1377's Avatar
69mach1377
I think a 295mm wide tire is about the max without too much trouble.
Old Jan 24, 2012 | 10:37 AM
jojobanks's Avatar
jojobanks
that's about 11.6". if that's the case then I should have no problems with a 10.5". The thing is can I have a 19-20" (17" rim 50-60mm tall tire) total wheel diameter and still maintain the same width with no rubbing issues assuming correct backspacing.
Old Jan 25, 2012 | 03:38 PM
69mach1377's Avatar
69mach1377
Is this car a lowrider with 20" diameter tires?
I can't imagine what the ride would feel like...
Old Jan 25, 2012 | 04:29 PM
jojobanks's Avatar
jojobanks
no it's lowered 1" and the new rims will be 17x 10 or 10.5 in the back and 17x8 up front. But with the tire on the overall diameter will probably be around 19".
Old Jan 26, 2012 | 01:20 PM
69mach1377's Avatar
69mach1377
Wow...not much room for air in there. What is the tire size exactly?
It might look like a lowrider though, but it is yours to do with what you like.
Am I the only one here surprised by this?
Old Jan 26, 2012 | 02:20 PM
jojobanks's Avatar
jojobanks
I want the rear tires to tuck a little bit. I think initially I'm going to mock up with a 255 50R17 and see how that fits. I'm just going to stick with a 10" wide rim.
Old Jan 26, 2012 | 03:05 PM
69mach1377's Avatar
69mach1377
I think the tire diameter for 255/50/17 would be around 27", which is kind of tall, not 19" which is way short.
http://www.1010tires.com/TireSizeCal...?action=submit
Old Jan 26, 2012 | 07:31 PM
jojobanks's Avatar
jojobanks
thx that link is very helpful. From what I looked through I'd be best off with a 285x40 17 tire. Thinking about the nitto nt555. Overall diameter is just under 26". I'd like to get something like a 285x30, but the calculator says that tire isn't produced?
Old Jan 26, 2012 | 08:31 PM
1slow67's Avatar
1slow67
ROTM Moderator
Yeah it looks like the lowest they go is 285/40 for that
Old Jan 27, 2012 | 05:59 PM
69mach1377's Avatar
69mach1377
Or 295/35,,,
