Cowl vent
Old Sep 14, 2005 | 11:17 PM
pak133's Avatar
pak133
Default RE: Cowl vent
Fender bolts on
The bolts in the engine conpartment, one underneath the rocker one from inside to the left of the fuse box and one bolt you'll see if you open the door and look directly towards the fender from the door hinge. Not too bad to take off.
Chip Foose would do something way cooler than just fix the cowl...but I like classics....
Old Sep 16, 2005 | 12:41 PM
ivanr77's Avatar
ivanr77
To take the fender off, youre gonna have to remove half the front end of your car. Mustang's are unibody so just about everything is connected to something. Cowl vent work is expensive but it can be done by yourself if you take the time and have the patience to do it. You do NOT need a mig welder. You can use weld bond adhesive instead, I've used it in several cases and i've seen it used on Cowl vent repairs. Ive had no problems with weld bond adhesive yet...except that its expensive.
Old Sep 16, 2005 | 01:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
You are not talking about JB-weld are you? If so, you may have had luck with it, but I haven't. If not, then what is it, and where can you get it?
Old Sep 16, 2005 | 02:13 PM
pak133's Avatar
pak133
I think I'd be a little afraid to use anything but a welder on the cowl vent. It is held on with 200 spot welds for a reason. Just 'glueing' it on seems liek a reciipie for disaster.
Phil
Old Sep 16, 2005 | 02:16 PM
ivanr77's Avatar
ivanr77
I'm talking about SEM's weld bond adhesive:
I haven't tried JB weld so i couldn't tell you anything about it. SEM has worked great for me (so far). I've used it to glue on my roof and i havent had any problems with anything since early this year even while taking corners at higher speeds, nothing "popped" out. I also have a friend who replaced a roof skin on his Nova about three years ago also using SEM weld bond adhesive and his roof looks great even to this day.
As far as where to get it, you can get it at just about any hardware store or home improvement. Im not sure if Napa/pep/advance carry this, they may but i wouldn't count on it.
Old Sep 16, 2005 | 02:20 PM
lClutchl's Avatar
lClutchl
I'm with Pak on this one... the article posted above talks about having to reinforce the body to keep it from sagging while the repair is in progress. That's just sitting still. I'd feel a lot more secure with good old fashioned welds in a structural area.
Old Sep 16, 2005 | 02:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
Thanks for the info Ivan. I learn something everyday.
Old Sep 16, 2005 | 02:43 PM
pak133's Avatar
pak133
IclutchI:
I just read the article from mustang monthly and didn't see anything 'about having to reinforce the body to keep it from sagging while the repair is in progress' Did I miss something or was it a different article?
Thanks for the info.
Phil
Old Sep 16, 2005 | 04:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I agree Clutch. But what is this crap about reenforcing the body to do a cowel repair> That cowel area doesn't support any body structural enforcement while the car is sitting still.
Old Sep 16, 2005 | 05:44 PM
lClutchl's Avatar
lClutchl
Working on one side at a time allows for the most amount of strength to remain in the cowl area to prevent misalignment or warpage. The left-side cowl hat area is now free to be removed. We now have only good metal to weld to.
Sorry, I read it yesterday and was working from memory. If you were to do both sides at the same time you would need some kind of reinforcement.
