MPG for a 302 & 347
Old 02-11-2012, 07:08 PM
Rols574
Rols574's Avatar
Default MPG for a 302 & 347
as the title says, just looking for some info on city and highway driving. I'm thinking a 6 speed tranny would go a long way into pushing those numbers up. Which 6 speed would be a good choice with each of those (the 302 and the 347)
Rols574 is offline
Old 02-11-2012, 07:15 PM
MonsterBilly
MonsterBilly's Avatar
I'm getting 21 mpg on the highway with a 289 4bl carb and a T5 trans with 3.73 gears
MonsterBilly is offline
Old 02-11-2012, 07:21 PM
Rols574
Rols574's Avatar
yeah i have a 289 as well but i have the old 3 speed on it. i was looking for a little more power without sacrificing too much MPG. the reason MPG is a big deal is 'cause its a daily driver.
Rols574 is offline
Old 02-11-2012, 07:31 PM
MonsterBilly
Well, I drive mine about 3 days a week and I built it up a bit. It's actually a pretty quik little car. You can if you want to. Have a lurked extra power but not spend a ton of $ throw a 100 shot of nitrous on it. It's safe easy and fun.
Old 02-11-2012, 08:38 PM
musnicki
musnicki's Avatar
Mine is a 302 bored .030 over, performer rpm heads, airgap intake, matching cam, 6AL MSD box, Holley 670 Street Avenger (72 primary, 68 secondary jets), 5 speed manual (.68 5th gear) and 3.89 gears.
I average 12-13 mpg in the city, but I occasionally drive like a jackass. On the highway (I drove from North Carolina to Mass and back) I get 20 mpg.
James
musnicki is offline
Old 02-12-2012, 07:29 AM
Stangatic
Stangatic's Avatar
If your looking to improve your MPG, save your money on the 6 speed trans and just get an EFI setup. On either engine setup that you go with, the EFI will help the engine run more efficiently. Depending on your driving characteristics, you would probably achieve around 25 - 27 mpg with a 302 EFI, rear gears that aren't too steep, and a C4/C6 trans.
Depending if you go with the EFI setup that was found on the 86-93 mustangs, you might have enough money left over to do a big part of a 5 speed swap. But that swap may only get you another 2 mpg.
Stangatic is offline
Old 02-12-2012, 08:05 AM
Stangatic
Stangatic's Avatar
^ that's highway MPG!
With my setup I am lucky to get 15mpg on the highway, however, I will be going with an EFI setup shortly.
Old 02-12-2012, 02:24 PM
eZ
eZ's Avatar
There are times when I get about 7mpg and love it!
eZ is offline
Old 02-12-2012, 08:22 PM
67 evil eleanor
67 evil eleanor's Avatar
The one with the lowest final drive for hwy. In the city, it's not gonna matter much.
67 evil eleanor is offline
Old 02-12-2012, 09:59 PM
Rols574
Rols574's Avatar
Who doesn't!
EFI makes that big a deal? I thought EFI was good for no more than 5 and that was pushing it
Rols574 is offline
Quick Reply: MPG for a 302 & 347
