how do you remove 1969 Passenger Window?
I am going to try to fix my passenger window on my 69 mustang. it rolls up and down fine, but once its goes up, the window is actually leaning towards the hood and there is a gap between the window and the popout window.
I can temp fix the window but just pulling the window back so the door can shut right.
I already took the door panel off of it, so how do you take the window and track out?
unbolt it from the regulator, and take the rubber gasket off of the back of the door. It has to slide out through that hole. You also have to unbolt the slides. Be careful when putting them back on as the threads are very soft and will strip easily.
DreadPirateRoberts
Sep 26, 2015 02:11 PM
jessicarabbit
Sep 25, 2015 12:41 PM
