Red, hot wire on headlight switch
Old Feb 16, 2012 | 04:09 PM
oxfordbp's Avatar
oxfordbp
Default Red, hot wire on headlight switch
it has a factory connector on it and is just hanging out ready to plug in somewhere, but I cannot find anything for it? Its only hot when lights on.
Old Feb 17, 2012 | 05:44 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
maybe a lead for a console light or a clock/rally pack etc
Old Feb 17, 2012 | 07:03 PM
oxfordbp's Avatar
oxfordbp
Good point. i just dont want there to be something disconnected that I dont know about.
Old Feb 17, 2012 | 07:06 PM
oxfordbp's Avatar
oxfordbp
Maybe you would know this question too...
There is a male spade connection on the ignition switch that sticks out after the actual plug is hooked up. I found a female that fits it that has two lavender wires hooked to it. That is the only logical plug to fit it, and I have it hooked up with no issues.
My question is why isn't it on any diagrams? I cant find it anywhere!
Old Feb 17, 2012 | 07:30 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ford pretty much used one harness for every car....you dont want to fry something just randomly hooking up wires
here is a link out of the FAQ sticky for wiring diagrams the FAQ is packed with info
Old Feb 17, 2012 | 11:50 PM
JMD's Avatar
JMD
Unless your car is decked out with every available factory option, including those that Ford even considered, there WILL be loose ends. This is even more true on later model cars.
Old Feb 18, 2012 | 01:24 AM
oxfordbp's Avatar
oxfordbp
Good point, I will unplug it until I KNOW what it is for.
There doesn't seem to be a lot of info on 67-8 mustangs compared to the 64-5-6.
The diagrams only show vague wiring, at least the ones I found. the link you provided was good, but still inaccurate to my setup for some reason.
Old Feb 18, 2012 | 01:26 AM
oxfordbp's Avatar
oxfordbp
I always seem to forget about that! I do have several "OPEN" connections.
The stang came with the headliner already done, without a space for a light! It should be universal in all mustangs right, I should be able to feel for the mounting spot and cut my way in and add one, no?
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
