1966 289 help
Old Feb 18, 2012 | 01:48 AM
mustang66289's Avatar
mustang66289
Default 1966 289 help
i have a 1966 289 mustang and ive been having this problem where after it is driven for a little while it makes a "puff" noise from the exhaust when under acceleration and it doesnt really change with how hard i push it.ive changed the spark plugs,spark plug wiring,ignition coil,radiator,water pump,thermostat,all hoses,fuel pump,oil,oil filter. over heating isnt a problem,and there is no kind of smoke or anything coming out of the exhaust.
Old Feb 18, 2012 | 02:36 AM
oxfordbp's Avatar
oxfordbp
Sounds like your running too rich and the unburned fuel ignites in the exhaust.
OR
Exhaust leak, but that's more of a ticking sound.
Someone else will chime in.
Old Feb 18, 2012 | 12:17 PM
Jonk67's Avatar
Jonk67
If you've got the stock exh. manifolds check the 'donut' gaskets between the exh. manifold and downpipe. Some are soft gasket type, I swapped to the all steel ones and cleaned up both surfaces and solved my exh. leak that I could hear. Probably not constant because it was more evident when the cylinder closest to it fired.
Jon
uberstang1
Dec 7, 2017 07:10 AM
GPR
Dec 16, 2015 12:21 PM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
