Backfiring
Old Feb 24, 2012 | 03:57 PM
oxfordbp's Avatar
oxfordbp
Default Backfiring
Why would I be backfiring after i shut er down? Doesn't seem to be running lean (sniff test) and I think the timing is ok, I don't have a light yet.
Could it be because I am idling too high, no tach yet either...I raised the idle cause it would die when I put her in gear.
Oh and I have a vacuum leak under the carb that I cannot get rid of, if that helps at all!?
Old Feb 24, 2012 | 04:37 PM
Stepman's Avatar
Stepman
Fix the vacuum leak and set the idle back down. That should take care of it.
Old Feb 24, 2012 | 07:04 PM
oxfordbp's Avatar
oxfordbp
Thanks
Old Feb 24, 2012 | 11:42 PM
musnicki's Avatar
musnicki
Also, check for a leak in the headers either from the heads or to your pipes. Not having enough back pressure can cause gas to drip down into the headers.
Running a bit rich can cause a back fire as well. When you shut the car off a few drops of gas can drip down into/onto the hot headers and ignite after the car is off.
It's definately not from bad timing, which would be another cause for a back fire.
James
Old Feb 25, 2012 | 10:27 AM
JMD's Avatar
JMD
You answered your own question!
A vac leak can get one or more combustion chambers too hot. When the fuel/air settles around a hot valve, or other hot spot in the chamber, the mixture is ignited, causing an explosion that can go up the intake, or down the exhaust.
If you have either aftermarket "big port" heads, and/or a "big port" intake, I have found that SBF intake gaskets can be a bitch to seal up, as they will "bolt in" in lots of positions that will not seal the ports, and the margins where the intake actually meets the head for sealing can be very, very, thin.
Old Feb 27, 2012 | 07:46 PM
oxfordbp's Avatar
oxfordbp
Sweet, fixed the vac leak, running real nice now. Thanks everyone
Sean
Aug 15, 2004 03:50 PM
Disgustang
Jul 27, 2004 09:43 AM
Obsol3te
Jul 26, 2004 08:42 PM
spuckie
Nov 21, 2003 05:51 PM
tchamber
Nov 9, 2003 05:47 AM
