New Coil Springs, need help
Old 02-28-2012, 08:39 PM
ashtoncrabtree
ashtoncrabtree's Avatar
Default New Coil Springs, need help
Ok i have a 66 mustang with a 302 motor, no other add ons and the coil springs are worn out even with the locks in them, so i am upgrading... along with the rest of the steering and arms and everything, my question is will these springs work? ---> http://www.mustangsunlimited.com/ite...atKey=EMUSTANG
I like the front being low like it is with the worn out springs, so i figured getting new ones with the one inch drop would be appropriate. please let me know if these will work compared to stock springs.......Also this car is not for looks its for DRIVING and PERFORMANCE so i believe the lower front stance gives me better cornering.
ashtoncrabtree is offline
Old 02-28-2012, 08:41 PM
oxfordbp
oxfordbp's Avatar
Add on the shelby drop while your at it!!
oxfordbp is offline
Old 02-28-2012, 08:55 PM
ashtoncrabtree
Details?, im on a college budget right now, so im doing standard fixes till i graduate next spring and start making the big dollars to play with.
Old 02-28-2012, 09:07 PM
1slow67
ROTM Moderator
1slow67's Avatar
http://dazed.home.bresnan.net/drop
1slow67 is offline
Old 02-28-2012, 09:08 PM
oxfordbp
oxfordbp's Avatar
http://www.opentrackerracingproducts.com/droptemplate/
oxfordbp is offline
Old 02-28-2012, 09:13 PM
ashtoncrabtree
alright thanks for the links im gonna bookmark them and have them ready for when ive got some more money to drop in it
Old 02-28-2012, 09:19 PM
oxfordbp
oxfordbp's Avatar
Dude its only 15 bucks for the drill bit and template. If you replace the springs this is a super cheap mod that will help your handling alot!
oxfordbp is offline
Old 02-28-2012, 09:31 PM
ashtoncrabtree
well i see that, but it talks about also having to modify some other thing or else it would cause faults at the ball joints
Old 02-28-2012, 09:32 PM
ashtoncrabtree
in reference to the other link above yours, it said other modifications needed to be done.
Old 02-28-2012, 09:37 PM
oxfordbp
oxfordbp's Avatar
Not really, those mods are only if you go more than 1"-1 1/8". More than that you need the other kit and stuff.
All you would need to do is a good alignment when you put her back together, but you have to do that after the spring replacement anyway.
oxfordbp is offline
Quick Reply: New Coil Springs, need help
