What Size...
Old Sep 16, 2005 | 02:08 PM
jes72mustang's Avatar
jes72mustang
Default What Size...
are the water lines that go and from from the engine block to the heater core on a 72 with 351C 2v? It appears that mine were replaced at one point and the wrong ones were put in. I do not like where there run across the top of the Valve covers and want to re-route them. Since I have started replacing hoses in theengine bay with braided, I want to go that way with these. I need to make sure I get the right size the first time because as you know that stuff isn't cheap. I want to see if any vendors at Fall Carlisle sell the hose by the foot to save a bit.
Thanks
Old Sep 19, 2005 | 10:00 AM
jes72mustang
Default RE: What Size...
BUMP! ANYONE? ANYONE?
Old Sep 19, 2005 | 10:48 AM
Soaring's Avatar
Soaring
I ♥ Acer
The rubber ones are 5/8" hoses. I don't know about the braided ones. As far as routing, I really don't know because I can't visualize your engine bay. Maybe run them over to or near the shcok towers then along the inner fender to the heater?
Old Sep 20, 2005 | 09:39 AM
jes72mustang
Thanks Soaring,
I have actually been researching the routing by checking out similar stangs at car shows, and I am most likely going to route over to and along the passenger side shock tower.
Justin_time
Aug 16, 2014 10:28 PM
l00kitzzlilcj
Sep 2, 2013 06:36 PM
68dustin
May 1, 2013 01:54 PM
Jericho
May 4, 2012 11:13 PM
topdeadcenter
Apr 16, 2010 10:11 PM
