Water temp. sender unit problem
Old Mar 14, 2012 | 03:40 AM
DejanM31's Avatar
DejanM31
Default Water temp. sender unit problem
Facts: Mustang Coupe 1965, 302 engine. Water temperature gauge jumps over 100% seconds after i start the engine. I tried a different 100% working gauge and the result is the same, so gauge is not the problem. Wires are all new. I have replaced temp. sender unit with a new one, and problem is still the same.
Engine works fine and doesn't overheat.
Any ideas what could be a problem?
Old Mar 14, 2012 | 06:51 AM
scootchu's Avatar
scootchu
Sounds like a short to ground somewhere. Does the gauge go down if you disconnect the sending unit?
If you have a meter check for continuity between the sending unit wire and ground. If you have continuity, then somewhere you have a short to ground.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
