manual steering link
Old Mar 25, 2012 | 05:01 PM
MonsterBilly's Avatar
MonsterBilly
Default manual steering link
http://www.cjponyparts.com/STEERING-...-1966/p/DS701/
Is this the steering link i need to convert my 66 from the factory power steering to manual? is there any other part i need? i heard that i also need a tie rod end but im not sure
Old Mar 25, 2012 | 05:12 PM
chockostang's Avatar
chockostang
Yes, this will change your Power Steering to Manual.
Are the Drivers side Tie Rods different?? Yes. The Drivers side are different, but you can "Rig" the Power Steering to fit. To do it Right, put in the correct 713/2004s/336R Tie rod.
Dan @ Chockostang
Old Mar 25, 2012 | 05:17 PM
Gun Jam's Avatar
Gun Jam
I think you need this one.
http://www.cjponyparts.com/BORGESON-...-1966/p/DS702/
Because its American made ( last I heard you should confirm this with CJ)
I am also uncertain about tie rod ends. I know they are different but the guy at CJ said the PS ones would fit. IIRC Rmodle said they would not and I would need inner tie rod ends...
Old Mar 25, 2012 | 05:18 PM
MonsterBilly
Dan, is this the one?
http://www.cjponyparts.com/TIE-ROD-E...1966/p/ES336R/
this is for the outer, Do i need to get the inner as well? Im a little confused.
Old Mar 25, 2012 | 11:40 PM
jp1967stang's Avatar
jp1967stang
Yes you will need inner and outer just on the drivers side. You will also need the adjusting sleeve on the drivers side. The one above is the right one for drivers and passangers outer on manual steering. And the steering link is the right one also.
I have herd the outer tie rod is the same for power and manual on drivers side. Think the power steering one is a bit shorter and you can cut it to add power steering. Im not 100% tho, for 20 dollars its not worth it to find out, i would just get the outer.
CS2007
Jun 25, 2019 09:45 PM
flash_xx
Oct 16, 2015 07:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
BeatnikFink
Oct 1, 2015 08:00 PM
