regarding flooded carb
Old Mar 26, 2012 | 10:33 AM
Toastintx's Avatar
Toastintx
Default regarding flooded carb
Ok guys see if this is legitimately. New eddy carb I have a glass fuel filter, when engine is turned off when hot fuel filter bubbles like its filling up, mechanic said it was probably a hairline crack in the base. Does this sound possible on a new carb
Old Mar 26, 2012 | 11:18 AM
Gun Jam's Avatar
Gun Jam
sure its possible.
Fire it up and spray carb cleaner around the entire base of the crab. listen for the idle to change. if there is a leak you'll find it that way.
Fuel can boil without an air leak from a cracked base as well there are other reasons.
Old Mar 27, 2012 | 07:52 AM
kalli's Avatar
kalli
might just be your fuekl boiling when hot. I'd shove a phenolic spacer in there after you tried what GJ said
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
