Continuing the effort; Welding
Old Mar 28, 2012 | 11:55 AM
bluemustang1966's Avatar
bluemustang1966
Originally Posted by JMD
Using the mig process, we never weld sheetmetal, we either spot it in, or use very short stitch welds. (joined together to form a solid weld if desired). Unless a person wants to fix a bunch of distortion, and fill a bunch of burn throughs, migs are for spotting and stitching.
the TIG process is better suited for more or less continuous welds on sheetmetal....
So are you saying when I do the floors I should do spot welds around the panel until it is closed up? i.e. start on left and move in a circle around the panel just spot welding each side to avoid warping.
Old Mar 28, 2012 | 12:15 PM
JMD's Avatar
JMD
Exactly, you will be able to tell pretty quick how big of a spot or stitch you can get away with once you get started, regardless, you will want to spot it in around it's circumference right from the start to minimize the warpage you are going to have to deal with later.
Old Mar 28, 2012 | 05:26 PM
LynnBob Mustang's Avatar
LynnBob Mustang
Originally Posted by Coupe
Lynbob, thanks for proving my point.
The word "hidden" just does not work for me.
No problem.
Although there is a big difference between properly hidden and butchery. What works for some just doesn't work for others.
Lynn
Old Mar 29, 2012 | 11:16 AM
abrush's Avatar
abrush
Yes, I am fully aware that a consistent weld will burn through or warp the metal. I should have clarified myself. I actually had troubles with the spot welds burning through.
Old Mar 29, 2012 | 01:41 PM
lil bull's Avatar
lil bull
Don't forget about wire lead length. the longer the length from the gun nozzle the cooler the weld. Gun technique and trigger techinque are important to learn while using the mig, don't just try to use the speed and voltage controls.
Old Mar 31, 2012 | 11:27 AM
bent metal's Avatar
bent metal
Looks like you got some good advise. I think some one mentioned, it's not "MIG or Flux". With a MIG you can use flux cole wire with no gas, or you can use solid wire with gas. Both are still MIG.
In my opinion, flux wire is for outside stuff. Like building gates etc. Where a breeze would blow away your shielding gas. So you need flux core to protect the weld pool. You want to weld inside your shop with welding gas, not flux. Much better weld, no slag, just better for what you want to do.
I want to agree with what some one else wrote about welding joints. When in doubt, copy what the factory did. That's what I try and do. The outer body panels that are being patched should be butt welded too, with a TIG, not MIG. Or gas welded with a torch. So you get better weld penitration and a weld that is soft enough to hammer smooth. For some reason a MIG weld doesn't like to be hammered on much. It tends to crack right next to the weld if planished. The torch and TIG do not. ...I don't know why.
Old Mar 31, 2012 | 01:28 PM
JMD's Avatar
JMD
I will agree, that gas would have been at least marginally better than flux core on the heat issue. I prefer to gas weld even beside this point.
I posted a general answer, for more or less general consumption even though I was answering your post. (I should have been more clear)
You would be surprised how many folks are set on "doing things right" by wanting to run a consistent bead all the way down a joined sheet metal joint. This seldom works out well...
cr620
Oct 3, 2022 10:18 PM
rgingo
Forum Issues and Feedback
Oct 21, 2015 12:49 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 17, 2015 07:57 PM
ryland
Sep 13, 2015 12:35 PM
