electronic ignition
Old Apr 22, 2012 | 03:22 PM
sid1108's Avatar
sid1108
Default electronic ignition
I'm putting in electronic ignition. If the engine is running smooth now, do I have to adjust the timing after the switch? Do I need to upgrade the plugs or are stock plugs ok. Thanks
Old Apr 22, 2012 | 06:26 PM
Starfury's Avatar
Starfury
Definitely need to retime afterwards. Stock plugs are fine, although you may open the gap a hair.
Old Apr 23, 2012 | 05:22 PM
sid1108's Avatar
sid1108
Thanks
Old Apr 23, 2012 | 09:34 PM
BuckeyeDemon's Avatar
BuckeyeDemon
what do you mean by electronic ignition? is this just a conversion from points to a mag pickup or are you changing distributors?
Old Apr 24, 2012 | 05:30 PM
sid1108's Avatar
sid1108
no just replacing the points. I was planing on keeping the stock distributor. Also would I set the timing? I haven't dealt with a timing light for a long time.
sid1108's Avatar
sid1108
were would i set the timing?
Old Apr 24, 2012 | 05:39 PM
sid1108's Avatar
sid1108
I mean is it always set at tdc
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Wombatnation
Sep 13, 2015 09:16 PM
