Driveshaft question?
Old Apr 23, 2012 | 06:44 PM
BuckeyeDemon's Avatar
BuckeyeDemon
i saw this thread, so i decided to go out and put a zip tie on the slip yoke.
i then put a floor jack under the rear axle, jacked it up so the rear wheels were about a foot off the floor and released the jack as quick as i could. i'm not sure if the rearend hit the rubber bumpers or not. it almost sound like it did.
the zip tie moved 0.146".
in my opinion on these leaf spring mustangs, the required slip distance is determined by how much slip you need to get the rear joint past the pinion so you can install it (which is probably on the order of 1/2").
Old Apr 23, 2012 | 08:11 PM
scootchu's Avatar
scootchu
I believe some Yokes are longer. Someone else with first hand knowledge might chime in.
Old Apr 23, 2012 | 11:32 PM
MonsterBilly's Avatar
MonsterBilly
yes, yolks are different lenghts. I had a new shaft built today and they took a C4 yolk and trimmed it to fit the internal length of the t5
Old Apr 24, 2012 | 12:21 AM
CyprusMustang's Avatar
CyprusMustang
Thanks guys, that is a big help. I'm gonna get my driveshaft cut today or tomorrow. Taking it to a machine shop so i can get it balanced too. Needs about two inches off! Then can install! I'm mounting a floor e brake so gotta put that in before I install the driveshaft.
Will be back .....
Old Apr 24, 2012 | 12:59 PM
scootchu's Avatar
scootchu
Here's what I have with suspension uncompressed and a T5 Tranny
Old Apr 24, 2012 | 08:58 PM
CyprusMustang
That looks a little tight in there....
Old Apr 25, 2012 | 10:45 AM
scootchu's Avatar
scootchu
Never been an issue. I believe it matches the space with the 4 speed that was in there.
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
