Door hinge plate
Old Apr 26, 2012 | 02:41 AM
Stangman70's Avatar
Stangman70
Default Door hinge plate
So I decided to fix my hinge pins and wound up doing things the hard way. After removing the upper hinge on the drivers side the plate that holds the hinge fell down into the A pillar and i was forced to remove the dash, not so hard on 70 but still time consuming. I was able to access the A pillar slot but have not been able to successfully draw the plate out. Any suggestions or tricks, maybe even a snarky comment or two?
Old Jul 28, 2012 | 10:54 PM
jayflight's Avatar
jayflight
.. Yep, I have had the same problem, and also would like to hear some advice, time saving advice if there is any around.....
Old Jul 28, 2012 | 10:55 PM
jayflight's Avatar
jayflight
... Yep, I have had the same problem, and would also like to hear some advice, time saving advice if there is any around.................. cheers
Old Jul 29, 2012 | 04:13 AM
Stangman70's Avatar
Stangman70
Jay, I found that you can remove the lower kick panel which will give you access to the lower plate. Other than that not much else but patience and trial and error. Magnets help too.
Old Jul 30, 2012 | 03:48 AM
jayflight's Avatar
jayflight
.. Yep, thanks Stangman, I finished up doing that.... the trial and error thing.... and finally had a win... but I was about to cut an access way into the outside of the A pillar, position the plate, then re-plate the accessway.... gotta be easier than all the B/S I went throught....cheers again and thanks.
jerrytubes
Oct 23, 2015 12:11 PM
Explosive
Oct 2, 2015 07:45 AM
mdg
Oct 1, 2015 07:04 AM
Sep 25, 2015 06:58 PM
