Old Oct 27, 2015, 11:21 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrain
Print Wikipost
Need to replace my radiator
Old May 13, 2012 | 09:08 AM
snafu7x7's Avatar
snafu7x7
Default Need to replace my radiator
I've got the original radiator on there now and its just come to the end of its life. I had it patched last summer to fix a leak near the bottom but now its time to put a new one in before it gets too hot.
I checked out NPD and got several results back (ignore the first one, but the other 8 all appear as though they will fit my car):
http://shop.autocraftinvestments.com...h_str=radiator
Can anyone speak to the differences between these models and what should go into my decision?
Thanks
Old May 14, 2012 | 08:29 AM
snafu7x7's Avatar
snafu7x7
bump...anyone know anything about these different models? thanks
Old May 14, 2012 | 10:17 AM
Gun Jam's Avatar
Gun Jam
Its a hard call Im not sure any of them are US made from the list alone I would initially pick 8005-1ee because of the 3 row and high fin count but i see it says no longer us made.
If I was really in your situation I would go to and get a norther aluminum one. Its quality made in America (last I checked) cools very well for a good price. I have been daily driving mine for the last 7 years or so in central Ca summers and winters.
http://www.northernfactory.com/store...&ctg_id=132229
-Gun
Old May 15, 2012 | 12:31 AM
65 hotrod's Avatar
65 hotrod
Go with 3 row aluminum I put one on my 65 restomod it runs 20 degrees cooler.
Old May 15, 2012 | 08:36 AM
Starfury's Avatar
Starfury
I have a factory replacement-style 3-row copper/brass radiator in mine and it works fine in 105+ heat here.
If you go with an aluminum radiator, stick with a good 2-row unit. 3-row aluminum radiators (ie. champion) are a gimmick. A good aluminum radiator will have at least 1" tubes, if not 1-1/4", while 3-row radiators usually use only 5/8" wide tubes. You actually lose surface area with three 5/8" tubes as opposed to two 1" tubes.
Granatelli Sales
Jan 20, 2020 12:34 AM
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
