Carb Spacer
Old Sep 20, 2005 | 02:42 PM
michaeldoggrell's Avatar
michaeldoggrell
Default Carb Spacer
I ran into a stupid "problem" which of course, none of the manuals describe.
But i am sure most of you mustang enthousiasts will know the answer to my question.
I got my carb spacer here, but i don't remember wich side goes up (and connects to the carb) and which side goes down (to the manifold)
Can you guys give me your opinion. Thx
Old Sep 20, 2005 | 04:48 PM
tylerdru's Avatar
tylerdru
Default RE: Carb Spacer
I would say that the second pic should go to the manifold.
Old Sep 20, 2005 | 05:05 PM
michaeldoggrell
Ok thanks. But hey, In my rebuild kit there are 3 identical gaskets. So i guess one goes on top of the spacer, the other one underneath and what about the third one ?
Where does it go ?
Old Sep 20, 2005 | 05:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
Tyler is right. The aluminum spacrers stilll radiate heat from the engine into the carb. If it were mine, I would replace the spacer with a phenolic spacer. You may experience vapor lock with an aluminum spacer, so I suggest a phenolic spacer. The old racers of old times just cut out plywood to use as spacers. It worked for them, as wood dispenses heat better than metals.
Old Sep 20, 2005 | 05:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: michaeldoggrell
Where does it go ?
That's an extra one in case you screw up with the first one.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
