vibration problems still
Old Dec 13, 2003 | 04:05 PM
pmfstang68's Avatar
pmfstang68
Default vibration problems still
i am still having vibration problems at higher speeds i got a new driveline, tires balance and alignment. the guys said at the tire shop i had some flat spots on my front tire and says that could be causing the problem. any help would be great </P>
thnx</P>
Old Dec 13, 2003 | 06:33 PM
65CoupRacer935's Avatar
65CoupRacer935
I have the same problem, I think I need an alignment.<IMG src=smileys/smiley11.gif border="0">
Old Dec 13, 2003 | 09:34 PM
68_stang_351c's Avatar
68_stang_351c
<FONT face="Courier New, Courier, mono" size=2> I also have the same problem in my 68 , but a allignment fixed it.</FONT>
Old Dec 15, 2003 | 06:18 PM
pmfstang68's Avatar
pmfstang68
maybe ill check it again for an allignment and see what happens </P>
thnx</P>
Old Dec 23, 2003 | 02:48 PM
bob emmerich's Avatar
bob emmerich
Could possibly be the u-joints on the driveshaft, wheel alignment,wheel balance,driveshaft balance(my best guess) or bad wheel bearings. If you had the alignment done, I woulddo some ofthe other things.
Old Dec 23, 2003 | 03:01 PM
Glengemen's Avatar
Glengemen
Flat spots can be felt at low speeds almost better than high speeds. If it is only at high speeds there could only be a ballance problem, bearings, or bushings. When you get to the alignment shop the tech should tell you if anything is loose, because you can't do a good alignment with bad bearings or bushings. Good Luck.
Old Dec 23, 2003 | 06:14 PM
pmfstang68's Avatar
pmfstang68
thanx ill have to check that out over christams if possible and tell you guys if i fixed the problem
Old Jan 15, 2004 | 05:07 AM
67beast's Avatar
67beast
check out the u joint
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
