pcv install questions (ghetto pics)
Old Jul 3, 2012 | 05:56 PM
kenash's Avatar
kenash
Originally Posted by rusty65
Also for the closed system, how would i run the line to my air cleaner? Would I have to buy a special air cleaner assembly set up that has a fitting to accept a hose run to it? And then what about the pcv port on the front of my carb? Just plug it?
Hi,
The typical closed system runs like this: The PCV is mtd. in a grommet on right rear V/C and routed to the PCV port on the carb. A second hose is connected from a closed oil filler cap to a hose fitting installed in the air cleaner base wherein a filter is added. See attached.
All of these parts, I found at the local auto parts store. I'll add, the added benefit of a good working PCV system is the reduction in crankcase pressures and a tendency for oil seepage through any weak seals and gaskets.
Hopefully these will give you an idea of how it works.
Attached Thumbnails pcv install questions (ghetto pics)-air-cleaner-filter.jpg   pcv install questions (ghetto pics)-modified-closed-vc-cap.jpg   pcv install questions (ghetto pics)-pass-side-with-pcv-buit-into-cap.jpg   pcv install questions (ghetto pics)-filter-adapter.jpg   pcv install questions (ghetto pics)-as-assembled.jpg
Old Jul 3, 2012 | 07:20 PM
rusty65's Avatar
rusty65
This brings me back to the problem of not having the hole/grommet in my valve covers that the pcv mounts in. So, I was thinking, would I be able to just get a new oil cap for my valve cover that had a breather tube (like the one in the pic you posted), then run a line off of it to the air cleaner and then from the ****** fitting that would be just below it on the oil fill neck run a hose to a pcv valve then run that to my carb?
Old Jul 3, 2012 | 07:23 PM
rusty65's Avatar
rusty65
If that will work, these are two of the caps ive found that seem like they may work:
http://www.foxbodyworld.com/ford-rac.../p/M6766FRVBK/
http://www.latemodelrestoration.com/...L-Oil-Fill-Cap
Then id just have to worry about clearing the hood with the pcv valve installed, on the second one that is....
Edit: One more quick thing, what about a pcv valve with an F fitting? would I be able to route one of those leads to the pcv input on my carb and the other to my air filter? (http://www.latemodelrestoration.com/...raft-Pcv-Valve)
And for that matter, what about installing a T fitting or something off of the one ****** fitting coming out of the neck of my valve covers, then routing one to my air filter then the other a pcv set up then to the carb? Seems like that would work better than using the F fitting idea, but as I type this Im realizing that that may cause problems because then I wouldnt build enough crankcase pressure to open the pcv valve would I? then itd just all route to the air filter....
Old Jul 3, 2012 | 07:32 PM
rusty65's Avatar
rusty65
apparently I cant say barb ed for some reason...
Old Jul 3, 2012 | 07:34 PM
kenash's Avatar
kenash
Hi
Funny! I just knew that question was coming. I'll be honest and say, I don't know that the benefit is the same. That is, think of it as cross-ventilation in a room. That is, air flowing in one source and out the other. I know it is a tough call, as I like those V/Cs too. But, in the end, if drilled properly they can be drilled nicely. In many ways, it's probably better to custom drill anyway, as you can place it in a more convenient place. But, be mindful of where you drill as the PCV must have clearance beneath it. That is, between rockers.
Hope this helps!
Old Jul 3, 2012 | 08:00 PM
rusty65's Avatar
rusty65
Yeah, the drilling itself wouldnt be a problem, its how I would have to go about baffling the valve covers once Id drilled the holes that has me concerned. Not to mention that then I have to worry about clearing my rocker arms with the new baffling in place...
I think at this point im just going to have to break down and get a set of tall valve covers that are already baffled so I dont have to worry about my rockers. So much for my nice blue, color matched valve covers
Old Jul 3, 2012 | 08:33 PM
kenash's Avatar
kenash
Hi,
If the truth be told, ....to make those (mine) regular height V'Cs work with my CompUltra Gold rockers, I removed the casting bosses and the "baffles". I too was nervous, but, to my surprise, there was no fall-out. I'm still using those V/Cs as I enter this.
So.......?
Old Jul 3, 2012 | 09:01 PM
rusty65's Avatar
rusty65
So youre running what I assume are 1.7 roller rockers in stock valve covers with no baffling and a pcv set up?
Do you not get any oil or anything gumming up the pcv valve? Also, what lift cam are you running? Because wouldn't that have a factor in determining the height of the rocker arms inside your valve covers at the peak of their travel? And what year / cid valve covers are they?
I suppose I could always give drilling the valve cover a shot, then if the pcv clogs Im no worse off because I was planning on buying new valve covers at this point anyway. Just a bit of clean up and a valve to replace.
Old Jul 3, 2012 | 09:09 PM
kenash's Avatar
kenash
Hi,
Nope! I'm running 1.6s. I don't need the additional lift as I'm lifting .570 on the intake and .562 on the exh. I get no ill affects from the loss of the baffles. My junk is a 48 year old 289 bored .040 over and stroke with a 331 kit. My V/Cs appear to be the same height as yours. Ask away, as I build my own junk and know what's inside. It makes 392 RWHP @ 6100
and 400 RWTQ at 4200.
Happy 4th!
Old Jul 3, 2012 | 09:13 PM
rusty65's Avatar
rusty65
Ok cool, Im going to give it a go with the valve covers Ive got and hope for the best. Thanks so much for all your help, and Happy 4th of July to you too!
