New Adjustable Brake Push Rod
Old Jul 3, 2012 | 04:34 PM
mike65gt's Avatar
mike65gt
Default New Adjustable Brake Push Rod
Am wanting to replace the standard pushrod on my 65 gt mustang to a adjustable one,a power booster was added sometime ago do I have to remove the whole booster and master to change this rod or can it be done in place and how is rod removed from booster is there some form of clip holding it in the back of booster.
Thanks mike
Old Jul 4, 2012 | 07:10 AM
chockostang's Avatar
chockostang
What booster??
Why change push rod??
Dan @ Chockostang
Old Jul 4, 2012 | 09:49 AM
2+2GT's Avatar
2+2GT
This will require some clarification. The 65 GT was never available with power boost. Therefore, we will have to know what sort of power booster has been installed. It is possible to install the OEM drum 64-66 power booster in a GT, but the pushrod on that unit was a flat steel plate, connected to a lever reduction linkage, not a rod. If your unit has a rod, it is an aftermarket unit, and we'll need to know what kind before we could even take a wild guess at your question.
Why do you want to do this?
Old Jul 6, 2012 | 07:15 AM
mike65gt's Avatar
mike65gt
Default Ajustable brake push rod
Hi guys thanks for your advice.
Long story as short as i can be.
Yes after market booster but from a dealer and for a 65.
Did have the orginal 65 Gt front brakes but just now upgraded to Baer front brakes from CJ pony parts so everything new complete bolt on upgrade
But as before brake pedal soft, still to install adjustable proportional valve and also have scott drake ajustable brake rod from the pedal into booster but not sure how to remove present rod.
Have bleed everything a number of times now with no improvement.
Any advice would be great
Thanks mike
Old Jul 6, 2012 | 04:03 PM
chockostang
Number one--
You can't remove push rods in these boosters. If a non adjustable now, it will remain that way, or cut thread, Cobble it up.
Number 2-
Putting in a adjustable push rod will do absolutely nothing to fix you problem. There have been may responses to "Adjust the push rod" and this does not pertain to the pedal push rod, it is solely for the master cylinder side push rod.
You need to Forget you quest, look at other factors.
Kinda blunt here, but this will save you BUNCHES of time, money.
Dan @ Chockostang
Old Jul 7, 2012 | 03:39 PM
mike65gt's Avatar
mike65gt
Default Push rod
Thanks Dan
Blunt is good
Will keep looking
Thought I would have stop on a dime brakes by now but something is not right
Will install proportional valve and see where that takes me
Do you think it is possible it may be to smaller booster for the car
Anyway thanks
Mike
Old Jul 7, 2012 | 04:23 PM
chockostang
I'm assuming you have stock rear drum brakes???
If so, does the new master have a 10 pound residual valve in the master (FRONT PORT OF MASTER).
If not, do a inline 10 pounder first.
How did you adjust the rear shoes---Adjust till lockup, then back off, GREAT!!
Dan
Old Jul 8, 2012 | 03:25 PM
mike65gt's Avatar
mike65gt
Default Brake Push rod
Thanks Dan
Will check out what you have mentioned
Mike
Sep 16, 2015 07:53 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
DoctorScary
Sep 9, 2015 07:53 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
RWHEELS
Sep 5, 2015 03:42 PM
