radiator support
Old Jul 19, 2012 | 04:07 PM
oxfordbp's Avatar
oxfordbp
Default radiator support
I need to replace mine, and am wondering if they are bolt in or weld on? Any how to videos or write ups on this?
Thanks
Also the front aprons.
Old Jul 19, 2012 | 05:25 PM
groho's Avatar
groho
I know on the 66 it's a weld in. with all the front end off, including the fenders, its not that complicated, just time consuming to removing everything, and then putting it all back. This includes the radiator and fan, etc.
Old Jul 19, 2012 | 05:40 PM
oxfordbp's Avatar
oxfordbp
I have never gotten into anything like that before, so im a bit nervous. I dont want to mess up so bad that it will cost more than it should have ya know..
Old Jul 19, 2012 | 08:43 PM
Coupe's Avatar
Coupe
Just use a small drill to make a pilot divot in the spot welds, then use a spot weld cutter. Just remember that the new piece uses the holes in the top of the aprons for alignment. Those holes are for the last fender bolt so be sure to look at everything before you remove the old one.
I used a spot welder to weld my new one in place and it would be hard for a casual observer to tell its been changed.
Old Jul 20, 2012 | 06:47 AM
BuckeyeDemon's Avatar
BuckeyeDemon
has the original already been removed from your car?
Old Jul 20, 2012 | 10:37 AM
oxfordbp's Avatar
oxfordbp
Im not sure, but I do know that it is in bad shape, I think it has been in a collision.
Old Jul 20, 2012 | 03:01 PM
jlg2002's Avatar
jlg2002
Here what you need to do to remove the battery tray apron and rad support.
and here is the after shot
You want to measure the hood opening diagonally rear to front before you start and then match those dimensions while you're laying in the new sheet metal. there is a Mustangs monthly tech article in June 2006 that shows the process.
Old Aug 4, 2012 | 03:32 PM
1967MustangCoupe's Avatar
1967MustangCoupe
Can you do this without pulling the engine? All the pictures I've found on the internet for this type of project have the engine pulled. Also, If you replace the left fender apron at the same time, what do you do about the VIN number stamped in the metal? Can you stamp in a vin on the new piece or do you have to cut it out and weld it into the new metal?
Granatelli Sales
Jan 20, 2020 12:34 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
MusicCity615
Sep 12, 2015 07:05 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
