Rebuilt Power Control Valve - Now Problems
Old Jul 24, 2012 | 12:14 PM
palerider's Avatar
palerider
Default Rebuilt Power Control Valve - Now Problems
I rebuilt my power steering control valve because it had a serious leak at one of the zerks. No leaks but kind of intermitently not getting full power steering on slow speed. Primarily parking lot speeds. Seems okay at higher rpms. Started mostly when turning to left - now does in either direction. I used Type F fluid when replacing. Power steering pump is fairly new. Was not doing this prior to rebuilding control valve. Any suggestions? Thanks
Old Jul 24, 2012 | 07:57 PM
oxfordbp's Avatar
oxfordbp
Air in the system?
Old Jul 24, 2012 | 09:40 PM
palerider's Avatar
palerider
I don't think so bled it a few times. Full side to side turns.
Old Jul 25, 2012 | 01:44 AM
guitarman376's Avatar
guitarman376
Maybe a gasket/o-ring was bad or it didn't sit right?
guitarman376
How is the pump belt tightness?
Old Jul 25, 2012 | 06:33 AM
palerider's Avatar
palerider
I'll double check the belt but seemed tight last time I looked.
Old Aug 6, 2012 | 07:28 AM
palerider's Avatar
palerider
Belts are tight. had to parrellel park last night what a pain. Is there a way to check the pump?
Old Aug 6, 2012 | 09:09 PM
guitarman376
I dont know if theres a way to check the pump, but it's possible I guess. Take it all apart and start inspecting parts for defects. Pumps don't fail too easily, so my guess is control valve or ram. Did you connect the short hoses on the ram correctly? I think thats a common mistake too.
Old Aug 7, 2012 | 06:24 AM
palerider's Avatar
palerider
I bought another pump for 50 dollars at autozone - will try that and if still a problem will return and keep ccecking. Could be right on shorter hoses to control valve but I though if you mixed those up steering becaomes some erractic and can jerk around.
Old Aug 7, 2012 | 02:48 PM
guitarman376
That's true...I guess we'll see if the pump was the issue.
