Auto transmission?
Old Sep 2, 2012 | 06:06 PM
wonso79's Avatar
wonso79
Default Auto transmission?
Should a automatic transmission still shift into gear if the radiator is out of the car, the transmission cooler lines not connected and the battery is disconnected?
Thanks
Old Sep 2, 2012 | 06:36 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you are not gonna have line pressure...and youre gonna burn up the tranny running it like that
Old Sep 2, 2012 | 06:40 PM
wonso79's Avatar
wonso79
I don't want to run it, just trying to figure out why my auto transmission is rolling around like it's in neutral. just got it back from having the a 8" rear end installed in my 65 inline 6 and they pulled the motor and trans but didn't do anything to them. So wondering if not having things connected from 6 months would make the transmission seem to be in neutral?
Old Sep 3, 2012 | 07:24 AM
Firstgothenshow's Avatar
Firstgothenshow
Forget the line pressure comment for now, because your not running the engine and are just trying to shift through the gear ranges. You should be able to hit all gears / positions of the transmission, period. If in park and still rolls around then the transmission linkage is; not connected, bent or out of adjustment. A simple under the car visual check should let you see if it is connected or has a new shiny spot where it got bend during removal or installation. There would be no need to change the adjustment just for a removal & installation of the same transmission.
Old Sep 3, 2012 | 07:52 AM
wonso79's Avatar
wonso79
o.k. i hooked up everything except battery and now I can get into park and the car doesen't roll but still rolls in the other gears. Is this normal?
Old Sep 3, 2012 | 09:25 AM
imnezrider's Avatar
imnezrider
IMHO...Totally normal, as long as it's not in park.
Old Sep 3, 2012 | 09:56 AM
wonso79's Avatar
wonso79
O.k. great!!
Old Sep 4, 2012 | 05:02 PM
jlg2002's Avatar
jlg2002
The difference between park and the other gears is a parking pawl that is engaged to effectively hold the output shaft locked.
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
