Engine Noise
Old Sep 3, 2012 | 07:37 PM
Stangman70's Avatar
Stangman70
Default Engine Noise
So after getting my power brakes installed on my coupe I go out to the garage to continue to break in the pads and I turn my car over and am greeted with this obnoxious noise! I am pretty sure that it is a lifter or a push rod not sure which. Any insightful ears are appreciated.
http://youtu.be/-zBbKrTIsLc
Old Sep 3, 2012 | 08:13 PM
Gun Jam's Avatar
Gun Jam
Yep thats a safe bet.
I had the same issue I used one of the mechanic stethoscopes to locate the source of the clicking. It worked very well I simply placed the probe against the valve cover and moved along the lenght of the cover until I could hear the clicking through the stethoscope. Pulled the cover off and found a rocker arm flopping around and a bent pushrod.
I would not drive it until you can id and repair the issue. I let mine go too long and it damaged the valve stem.
-Gun
Nick Oliver
Oct 17, 2018 04:22 AM
bjdutch2005
Mar 24, 2017 03:38 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Emblazoned
Sep 3, 2015 10:45 PM
