C-4 speedo gear
Old Oct 9, 2012 | 05:43 PM
rogermbell's Avatar
rogermbell
Question C-4 speedo gear
How difficult is it to change the driven speedometer gear in a C-4 trans?
Thanks
Old Oct 9, 2012 | 08:09 PM
Firstgothenshow's Avatar
Firstgothenshow
Pretty simple, follow the cable down to the transmission, loosen the bolt holding the cable assy in the trans and pull it out. There is an O ring on the cable housing and I would suggest you clean around the cable boss area prior to removal so no dirt falls into the trans. There is a horseshoe style clip on the gear itself holding the gear in place. Prior to removing the clip, see how well it is seated so you know what to look for upon reassembly. I use oil, vaseline or brake grease to lube the o ring prior to installation. Remember the trans housing is aluminum so don't smoke / over torque the retaining bolt.
Old Oct 10, 2012 | 09:57 AM
rogermbell's Avatar
rogermbell
Default Thanks
Thanks much for the info, sounds pretty easy.
Old Oct 10, 2012 | 10:03 AM
rogermbell's Avatar
rogermbell
Default Which gear to use?
Now that I know how to change the gear, is there a way to determine which gear to use?
The speedo is off by about 10mph, rear axle is 3.31, tire size is 7.15x15, with the C-4 hooked up to a 351W.
Old Oct 10, 2012 | 08:29 PM
Firstgothenshow
Wink
Yo Bro, here you go
http://www.tciauto.com/tc/speedometer-gear-calculator
FORD SPEEDOMETER GEAR INFORMATION
Ford Speedometer Gears
Drive Gears Driven Gears
6 teeth - machined into output shaft (C6 only) 16 teeth - tan
7 teeth - machined into output shaft 19 teeth - tan
8 teeth - machined into output shaft 20 teeth - orange
9 teeth - machined into output shaft 21 teeth - red
23 teeth - white 1
- Ford drive gears are machined into the output shaft on C3/C4/C5/C6 & AOD transmissions. You may need to remove your tailhousing to determine how many drive teeth your transmission has.
1 - This is a retrofit gear to allow the speedometer to function with 3.73 and 4.10 rear end gears. Since the gear tooth pitch is slightly different than OE, the service life of this gear is limited to less than 25,000 miles.
Old Oct 11, 2012 | 10:01 AM
rogermbell's Avatar
rogermbell
Firstgothenshow,
You've been a great help-thanks.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
