which export brace is best
Old Nov 11, 2012 | 11:05 PM
Curtis Creekmore's Avatar
Curtis Creekmore
Default which export brace is best
who has installed the 1 piece export brace from mustangs unlimited and had trouble getting it to bolt on.
who has purchased somewhere else specifaclly west coast classic cougars they say theres are the best , have trouble or bolted on?
Old Nov 12, 2012 | 04:56 AM
Al Newman's Avatar
Al Newman
Chances are that ANY export braces you find will be difficult to just "bolt on", since the Mustang's shock towers most likely have caved in and maybe dropped back a bit. That's the reason you install an export brace. Get the front end geometry corrected.
As for quality, the original Ford is just the best. There are other good ones out there, but there are some really cheesy offerings, also that will fold right up. Really hard to know. I would personally stick with whatever Scott Drake is marketing if I could not find an original Ford.
Best,
Al
Old Nov 12, 2012 | 09:35 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
a lot of times you need to jack up the car and put it on jackstands and let the car relax for a day or so
Old Nov 12, 2012 | 11:30 AM
Coupe's Avatar
Coupe
I had a cheapy chrome unit that would not fit, no matter what. I ended up drilling a new set of holes in the brace knowing I would be overhauling the car in time. Once the car was coming apart I test fitted the heavy Drake piece and it dropped right into place with no struggle.
Dont go cheap. The Drake part fits and is much stiffer.
Old Nov 12, 2012 | 05:19 PM
RC65's Avatar
RC65
+1 on the Scott Drake heavy gauge one! No issues installing.
Old Nov 13, 2012 | 03:13 AM
tx65coupe's Avatar
tx65coupe
Definitely the deeper stamped heavier Scott Drake one. The same is true of the monte carlo bar.
guitarman376
Oct 11, 2015 01:47 AM
Sep 17, 2015 07:57 PM
Sep 16, 2015 07:53 PM
GentleBen
Sep 11, 2015 05:34 AM
