which radiator configuration do I need?
Old Nov 23, 2012 | 06:26 AM
OhioTed's Avatar
OhioTed
Default which radiator configuration do I need?
I'm doing an I6 to 289 swap in my '66 and am ready to purchase a V-8-application radiator. They are offered with offset inlets and outlets, and with same-side inlets and outlets.
How do I know which to select? My car has manual trans, manual steering and no AC.
Old Nov 24, 2012 | 01:52 AM
andrewmp6's Avatar
andrewmp6
Look at the 289 which way are the radiator hoses are pointed.The upper is the inlet the lower is your outlet.
Old Nov 24, 2012 | 06:34 AM
OhioTed's Avatar
OhioTed
Thank you. That makes perfect sense. I also found reference in Mustangs Plus' catalog, indicating the offset radiators for my application are utilized when converting to a 5.0.
Old Nov 24, 2012 | 07:59 AM
andrewmp6's Avatar
andrewmp6
They make a radiator for any engine you could swap in is why all the options for one.
Old Nov 28, 2012 | 12:41 PM
frdnut's Avatar
frdnut
It depends on what year the V8 engine is you are installing..The waterpump inlet is on the passenger side for cars 1969 and earlier..1970 and later are on the drivers side..The top hose from the intake will always be on the passengers side..If your engine is an original 289 it will have the water pump hose on the passengers side.
Granatelli Sales
Jan 20, 2020 12:34 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Beerman309
Sep 19, 2015 01:16 AM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
