393 stroker.
Old Feb 12, 2013 | 04:16 PM
65M's Avatar
65M
Default 393 stroker.
Hi, I have a 65 mustang that I'm thinking about doing a 393 stroker in. Its just a fun car that wont be road hard or taken to the track I just want something that will really go now and again when I want to play around. It currently has a 351w that has some modifications to it and I am wondering if the 393 stroker can be done with the block in the car and If it was possible for me to use a scat 3.850 crank, Keep my stock rods and order a set of 302 dished pistons for it. Also would this be a worth the money or would I not notice a real difference over my 351. The motor currently has a RPM intake, with RPM cam, The heads have been ported and polished with 1.94 and 1.54 valves and a set of mid length headers. Thanks
Old Feb 12, 2013 | 04:19 PM
69mach1377's Avatar
69mach1377
Find a free copy of Dyno 2000 online and run some numbers to get a feel for the difference it will make.
Old Feb 15, 2013 | 09:34 AM
htwheelz67's Avatar
htwheelz67
A 408 is about the same cost, yes you will feel a big difference but you will need some larger heads other wise using your current components you will have a smoother idle and massive torque up to about 3500 and it will drop off fast. You need to pull the motor to do it right.
Old Feb 20, 2013 | 07:12 AM
65M's Avatar
65M
Ok well then for now I'm gonna get a set of AFR #1388 for it and down the road I'll pull it out to stroke it. I just really dont have a place to do that again right now.
Old Feb 20, 2013 | 09:31 AM
dodgestang's Avatar
dodgestang
You need to take the block out to build the stroker motor.
Old Feb 20, 2013 | 09:53 AM
htwheelz67's Avatar
htwheelz67
I would go a set of twisted wedge 190 cc as cast vs afr's they have better low lift flow (even the 170cc do) over the afr's and they can grow bigger for a stroker where the afr's cant. I had the 170cc on my 351 and then had them cnc ported to 205cc for my 408.
Old Mar 12, 2013 | 11:56 PM
New69stang's Avatar
New69stang
Default 393!
Hey! my name is Sam. I am new here but this site is awesome!! I have a 89 351w block stroked to 393. I also have a probe forged internals kit minus cams and heads. What would everyone recommend? I want to maximize my potential power. Also, can I oversize the heads if i plan in supercharging soon?
Old Mar 14, 2013 | 10:20 AM
69mach1377's Avatar
69mach1377
This is a good free tool for ballpark estimates, especially for different combos.
sc351W
351 Mustang
Jun 21, 2008 09:45 PM
sc351W
351 Mustang
Mar 17, 2006 09:55 AM
5.0_Cobra
Oct 5, 2005 01:24 PM
mustangboy393
Jan 6, 2005 11:11 AM
johan6966
Jan 28, 2004 07:06 PM
