Modern Engine Classic Mustang
Old Jun 2, 2013 | 02:03 PM
Sergio Flores's Avatar
Sergio Flores
Default Modern Engine Classic Mustang
Hi I am new to mustang forums and wanted to know if anyone had any experiencing putting a new so 2005- present mustang engine in a first gen mustang
Old Jun 2, 2013 | 02:16 PM
ajzride's Avatar
ajzride
All it takes $$$$
Best thing to do is lose the entire front suspension and shock towers in place of a k-member style M2 setup. Check out TOtal Cost Involved, Rod and Custom, Detroit Speed Engineering, and Hiedts.
Old Jun 2, 2013 | 03:52 PM
67mustang302's Avatar
67mustang302
It's expensive. You'll get more performance for money spent by not using a "modern" engine. And even older pushrod engines can be made "modern" with the use of newer tech parts. Yeah, the block is the same, but that's not an issue.
Old Jun 3, 2013 | 05:43 PM
Jonk67's Avatar
Jonk67
Here's a few if you want to see what you're getting into:
http://forums.vintage-mustang.com/mo...ld-update.html
http://forums.vintage-mustang.com/mo...n-started.html
Jon
Old Jun 5, 2013 | 09:41 PM
65wildstang's Avatar
65wildstang
What are your concerns? Shock towers will need to be cut back or completely removed. Theres alot of fab work and diffently some trial and error. It is more expensive than a traditional 5.0 or 5.8 rebuild and swap, but I wouldn't hesitate to do it again on another build. Well worth it to me ,especially the cool factor. Good Luck
Old Jun 5, 2013 | 10:14 PM
67mustang302
General rule of thumb, if your ultimate goal is highest performance per $ spent, don't do the swap. If you just want a newer OHC engine for whatever reason (show car, cool factor, smoothness etc), then go ahead, but you'll have to spend money to do it right.
Though, with ANYTHING on cars, you have to spend money to do it right.
Diode Dynamics
28
May 26, 2022 12:02 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
AMWill
AmericanMuscle.com
26
Sep 8, 2015 01:32 PM
daytooday
Aug 11, 2015 09:22 AM
