temperature sensor replacement
Old Jun 7, 2013 | 01:27 PM
echoes's Avatar
echoes
Default temperature sensor replacement
My 1970 mach 1, 351 cleveland temperature gauge has stopped working. I am going to go through the various problem areas, temp sensor, thermostat and then the gauge. Is there any other possible problems areas? The sensor is located just below the thermostat/top right of water pump, do I need to drain any/all of the radiator? Thanks
Old Jun 7, 2013 | 01:35 PM
Iskwezm's Avatar
Iskwezm
With the key on, if you ground the wire, it should peg the guage to HOT.If it doesnt, there could be a break in the wire or the guage is bad.If none of the guages work, then it could be intrument voltage regulator or a power issue.
To change the sensor, just lower the fluid level to below the sensor.
Old Jun 8, 2013 | 01:42 PM
echoes's Avatar
echoes
Default Temperataure sensor
With the key on I checked the wire and got an indication that it is working but nothing on the gauge. I am assuming that my problem is not the sensor or the wire but the panel gauge. All other gauges are working. Thank you for your assistance.
5.0muscle
Jan 11, 2016 01:17 PM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Art161
Sep 9, 2015 10:33 AM
