whats a good carbeurator
Old 06-11-2013, 02:55 AM
kevlong2
kevlong2's Avatar
Default whats a good carbeurator
So im fixing up my 66 mustang its an inline 6 cylinder and i wanna hive it a good carbeurator with some kick ive heard hollys are good but i dont know which one i should use is there a specific size i need please help i want a good carbeurator that gives my car a good kick thanks
kevlong2 is offline
Old 06-11-2013, 09:27 PM
JAGGUY
JAGGUY's Avatar
This is the place to find out about 6 cylinder performance
http://fordsix.com/forum/
JAGGUY is offline
Old 06-11-2013, 10:02 PM
67mustang302
67mustang302's Avatar
If it's a 6, just get the Autolite replacement.
67mustang302 is offline
Old 06-12-2013, 06:19 AM
120mm
120mm's Avatar
Welcome to my life. There really isn't an easy solution to your issue. Especially if you want "some kick". Right now I am following 67mustang302's advice, and running a stock Autolite, but my history with them is Not Good.
If you follow JAGGUY's advice, be prepared to do some reading; there isn't a "recipe" you can just follow to deal with the shortcomings of the small log Autolite combo.
120mm is offline
Old 06-12-2013, 07:26 AM
kenash
kenash's Avatar
Hi,
The "kick" you're seeking will only come from a series of parts and how well they coordinate, not simply throwing a carb at it. The site suggested by Jagguy is a good place to learn what others have done to improve the performance of their 6s.
Have you optimized what you have? An improvement might be had with a major tune-up including insuring your carb is working correctly (correct idle), distributor advance rate is working properly and the initial timing is correct. Also, knowing that compression and engine vac are within specs.
Happy Motoring....
kenash is offline
Old 06-12-2013, 09:52 AM
wsovonick
wsovonick's Avatar
Good advice from kenash. This guy KNOWS what he's talking about. For me, I've been running a Holley 1940 1-V in my 65 convertible for the last six years. Rebuilt it once. It's totally dependable and easy to work on. I too want a Mustang with more HP, that's why I'm now restoring a 69 Mach 1. :-)
wsovonick is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
ctgreddy
09-20-2015 08:35 PM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: whats a good carbeurator
