Heater Lines
Old Oct 8, 2005 | 01:45 AM
tylerdru's Avatar
tylerdru
Default Heater Lines
Does it matter where I put my heater lines? I have got 4 Holes on my new manifold that tap into the coolant, and was wondering if i could use the back two for the temp sending unit and heater lines, and plug the front two. This would clean things up.
Old Oct 8, 2005 | 10:08 AM
gta289's Avatar
gta289
Default RE: Heater Lines
if were talking for a 289/302 there are a total of two(2) lines for the heater/ the first sits on top of the intake manifold and should have an elbo fitting, the second is on the water pump itself. the intake will route into the uperpart of the firewall, and the waterpump goes to the bottem half. ill assume the heater core is good, if not youll know it!!! if that happens just by-pass the intake into the water-pump. hope this helps!
Old Oct 8, 2005 | 01:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: gta289
Joe, you missed Tyler's post a few days ago with pics of his manifold. He has 4 holes instead of two. I guess it really doesn't matter, but I would assume whatever has the cleanest and most direct route to the firewall.
Old Oct 8, 2005 | 06:21 PM
davin's Avatar
davin
I know i just put a performer 289 on my motor a month ago, I dont think those ports in the back have coolant access, I think the 2 in the back are induction & the 2 in the front are coolant, but i may be wrong, I used the whole on the Drivers front for my heater core with an elbo on it & the largest hole right behind the radiator neck for my thermo.
Old Oct 8, 2005 | 11:09 PM
tylerdru's Avatar
tylerdru
Gta, not to be rude but that was random
Davin i dont have a Performer, and i know for a fact that I have 2 ports in the back have coolant access. I did teh pinky test.
Now i just have to just find a better way/ hose for the heater line from the water pump.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
