Flooded & Stumped
Old Sep 29, 2013 | 06:35 PM
shea.mccullough's Avatar
shea.mccullough
Default Flooded & Stumped
Need a hand, don't know what to do next. I was tuning the 1406 Edlebrock carb on my 69 mustang with 351W. It flooded so I left it alone, went back the next day and got it to start, but couldn't again after it was turned off. It will not even turn or crank over. It has a new starter, spark plugs, battery, and fuel pressure is fine. I have never had this issue so am very lost.
Old Sep 29, 2013 | 08:11 PM
67mustang302's Avatar
67mustang302
Check battery voltage, check grounds etc.
Did it run ok when it started before?
Old Sep 30, 2013 | 07:42 AM
shea.mccullough
Yes, it ran fine when it started back up. The interior lights are working just fine. The battery voltage is 11.6, but this isn't low enough for nothing to happen right? All connections are good.
Old Sep 30, 2013 | 08:26 AM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
First off, charge your battery. If you don't have good voltage, you're jerking off.
If you are still getting no signs of life when you try to crank then is sounds like maybe the neutral safety switch if it's an automatic.
If it is then rip through the gears and slap it back in to park and see what happens.
Old Sep 30, 2013 | 11:12 AM
Gun Jam's Avatar
Gun Jam
Uhhh...how bad did it flood? Ive got to ask!
Did you happen to fill a cylinder up with fuel?? The engine rolled over a few degrees the intake valve closed and now you've got 4oz of raw fuel trapped in the combustion chamber and its hydro locked?
Try to use a large ratchet and I think a 15/16 socket on the crank and see if you can turn the engine to the right by hand...it should not take a ton of effort
Old Oct 2, 2013 | 10:29 AM
shea.mccullough
Default Fixed
Got it fixed. It ended up being the starter relay and just bad timing of it going out in the middle of tuning the carb. Thanks for the replies.
CMcNam
Oct 30, 2022 11:40 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
mltdwn12
Sep 23, 2015 08:54 AM
stangin1996gt
Sep 21, 2015 11:01 AM
