Performance Transmission
Old Jan 25, 2014 | 02:25 PM
NassEmirates's Avatar
NassEmirates
Default Performance Transmission
hi guys, i got 1965 mustang coupe with 347 windsor engine with 425 HP, im looking to buy a new Performance Transmission that can handle this engine and get all the power out of it, any advice ? thank you.
Old Jan 27, 2014 | 06:47 AM
palerider's Avatar
palerider
Assuming automatic. Check out TCI C4 - summit has them at good price. Have behind my 347 no problems.
Old Jan 27, 2014 | 05:05 PM
Gun Jam's Avatar
Gun Jam
Doesn't look like 425hp to me but it does look like a nice solid ride!
Assuming 5 speed get in contact with Bruce from ModenDriveline http://www.moderndriveline.com/index.html
Good Luck!
Old Jan 27, 2014 | 07:17 PM
67mustang302's Avatar
67mustang302
Manual or automatic? Is cost important, or availability/import duties an issue?
Old Jan 27, 2014 | 08:19 PM
NassEmirates
thanks guys it is automatic
Old Jan 27, 2014 | 08:36 PM
Gun Jam's Avatar
Gun Jam
The C4 is a pretty tough little dude especially if its built up a bit.
Do you not think the previous owner made any upgrades to the c4 thats in there now? Is it an all stock original?
Is the current transmission doing anything that seems like an indication of trouble?
-Gun
Old Jan 28, 2014 | 09:10 AM
Al Newman's Avatar
Al Newman
A C4 can only be built up to handle roughly 700 horsepower. Anything over that and you will need to look at a C6. As for standard trannys, and assuming that gas mileage is not so much of an issue, look at a toploader 4-speed. T-5's can handle only so much abuse before they become a headache. You will find tons of tranny suggestions, but the Ford based trannys are all I have had experience with.
Best,
Al
Old Jan 28, 2014 | 01:02 PM
NassEmirates
i used yo have 302 engine, then i requested to custom build a 347 engine 425 hP from engine factory close to 17k $, and shipped to me, installed it, had lots of temp (over heating problems) fixed that, turned out something was not right with the engine and fixed, temp is ok now, but the Transmission is acting funny and i been told that i need new Transmission, some say here i need 3 speed Transmission and some say better 4speed Transmission, i tried and changed 2 used Transmissions but they were not good, so i want to buy a new one that goes well with this type of engine.
Old Jan 28, 2014 | 03:19 PM
69mach1377's Avatar
69mach1377
Which rear gear do you have and how fast do you want to go?
You may or may not need an overdrive/4 speed trans.
Old Jan 28, 2014 | 09:20 PM
Gun Jam's Avatar
Gun Jam
could you please attach photos of said engine?...I would very much like to see this
Thanks
-Gun
