best headers
Old Feb 16, 2015 | 02:54 PM
  #21
Bigwhite's Avatar
Bigwhite
I have tri y's on my built 306. Forged bottom end ported edelbrock heads street avenger 670 etc etc. transmission is a built also, full reverse valve body higher stall torque converter. I like the tri y's don't have any leaks, I sent them out to get coated when I built the motor. 330hp 340tq
Old Feb 20, 2015 | 12:56 PM
  #22
69mach1377's Avatar
69mach1377
Originally Posted by dragman72
Just picked up a 69 and had some wiring and starting issues. got them all fixed up and had to put in a new starter. WOW that was a pain! headers and sway bar had it blocked in something fierce! Anyways the headers on the car are older and sounds like they leak a bit at the gaskets and they are long tubes and have a few flat spots on the bottoms from pot holes. so I want to replace them. what headers will give me the best clearence to work on car as far as starter plugs and stuff. and what kind of performance difference am I looking at between long tubes shortys etc??? engine is a built 302.
Maybe the starter is the problem...try one of those mini starters from a fox body. Mine clears easy.
Old Feb 24, 2015 | 06:57 PM
  #23
1966fastbach's Avatar
1966fastbach
Nothing compares to the ground clearance and fitment of FPA Headers.
Old May 12, 2015 | 05:12 PM
  #24
Slem's Avatar
Slem
I'm with 1966fastbach...FPA headers are da bomb!!! They'll make note of your size motor, heads in use and year stang then build you a set of headers that are beautiful and fit perfect!! I have a 68 FB with a 351W (bored/stroked to 427ci) with Dart Pro1 heads. That's an almost impossible combination to find headers for. FPA took my exhaust port size, port shape and built me a big tube stepped design that fits flawlessly!!! No clearance issues what so ever!
Old May 12, 2015 | 05:14 PM
  #25
Slem's Avatar
Slem
Conversely, I tried to get a tri-y set up from Doug's. Talked to them on the phone and actually got into an argument with the guy. He was an ***! I'd never buy from those ******!
Old May 13, 2015 | 09:46 AM
  #26
69mach1377's Avatar
69mach1377
What does something like that cost roughly?
Old May 13, 2015 | 10:25 AM
  #27
Slem's Avatar
Slem
Sorry bout the earlier rant...I'm certainly NOT a fan of Doug's!! If I want to give away a grip of cash AND get treated like crap I'll just get divorced!
The fitment of the FPA's is unreal! My Canton oil pan hangs lower then these pipes. I put a heat blanket around my starter for insurance but I don't think I really need it. Tried to upload a pic but it wouldn't take for some reason.
Anyway...I'd have to go thru my receipts for the exact price. They were a lil more then mass produced pipes but it was def worth the price tag...I wanna say $600-$800 for pipes and ceramic coating. Pricey but keep in mind they are custom fab'd.
Give em a call: http://www.fordpowertrain.com/FPAindex/headers2.htm
Old May 13, 2015 | 10:28 AM
  #28
Slem's Avatar
Slem
Hey! 69Mach1377! I just moved from ABQ! Surprised we haven't run into each other!
Old May 14, 2015 | 01:34 PM
  #29
Slem's Avatar
Slem
I put a pic up on my profile gallery showing the pipes. I think I have some more pics if you're interested.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
