new ignition
Old Oct 12, 2005 | 01:26 PM
valley firearms's Avatar
valley firearms
Default new ignition
As some of you may have read, I am in the market for a new electronic igniton. You can go back and read my post about the MSD 6AL if you have not. I want to keep the 6AL for performance reasons. I have read a lot about pertronix and am leaning toward that kit. I also was thinking about purchasing a complete pertronix HEI dist off e-bay. Then I thought maybe I should buy a darn MSD dist to keep the ignition all one brand. Anybody have any problems with the above mentioned? What do you love about them? How about maint? I still trying to decide. My money tree is still blooming(yeah right). If you like modding cars you need to keep that sucker well watered!
Old Oct 12, 2005 | 01:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: new ignition
You already have the MSD box. Why not just get the dizzy that is compatible with it?
Old Oct 12, 2005 | 03:11 PM
superdavid's Avatar
superdavid
With my basic knowledge of electronics, I would recomend sticking with just one brand. That way, you know the system is compatible and tech support will be better if there is a problem. Also, the MSD distributor I recently put in my 289 has been very solid and was easy install and tune.
Old Oct 12, 2005 | 05:43 PM
valley firearms
Thanks guys! That makes a lot of sense.
Old Oct 12, 2005 | 08:30 PM
69FECoupe's Avatar
69FECoupe
You might want to consider a Duraspark distributor. They are compatible with MSD in fact they make a harness to connect directly to the stock connectors. They are bullet proof and can be had for about $65.00 or so rebuilt. Alot of the FE guys go that route. Just a suggestion.
Old Oct 16, 2005 | 01:24 AM
valley firearms
Hey guys,
I purchased a pertronix and tried that with the MSD 6AL box and still no spark. It only took about 10 minutes to install the pertronix. I then bypassed the MSD and she fired right up
I went into the house and called Schucks to see if they would warranty the box. I figured that they wouldn't since it was an electrical item. Also I figured they would tell me to send it to MSD direct. I was shocked when the manager said she would exchange it. I guess she figured I spend a lot of money in there. They even had to bring one in from Anchorage. I went and picked it up today with no hassles. I like that kind of customer service!
Wish me luck. I will try to install this one tomorrow unless you can talk me out of it(except for Soaring[8D]) I guess if I were like Soaring I'd have less headaches. If it aint broke, don't fix it. But then again, I never was a good listener
Old Oct 16, 2005 | 02:00 PM
Soaring's Avatar
Soaring
I ♥ Acer
Mike, believe it or not, I have been through Wasilla, Alaska. There aren't many folks who even know where that little berg is. I was stationed at Ft. Richardson back in the 60's.
Old Oct 16, 2005 | 06:27 PM
valley firearms
Wow, back in the 60's there wasn't much in Wasilla. For that matter, in Anchorage. I do a lot of work on Elmendorf and Richardson as well as Wainwright. I moved here in 90 and Wasilla was still small. You should see it now[:@] A drive that probably took you 2 -3 hrs to get to Wasilla from post now takes 40 minutes.
Old Oct 16, 2005 | 07:05 PM
valley firearms
By the way Soaring, THANK YOU for your service to our country. I thank all who made the ultimate sacrafice, vets and active military [sm=patriot.gif]
If it weren't for you, we wouldn't have our freedoms and our Mustangs[sm=happy046.gif]
bradleyb
Nov 27, 2015 07:50 PM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jessicarabbit
Sep 25, 2015 12:41 PM
Wombatnation
Sep 13, 2015 09:16 PM
