'66 spindle help..
Old Mar 3, 2014 | 06:24 PM
nc98405's Avatar
nc98405
Default '66 spindle help..
So my first posting on here discussed some steering issues that I have on my 66... First some quick detail: I recently purchased a 1966 mustang coupe that is pretty close to stock with a lot of simple replacement parts as things have gone out.. It has an inline 6, manual steering and brakes..
In my first posting I had asked about some steering issues; went by a shop and they suggested simply redoing the front end to replace pieces like the tie rods, bushings, etc... But as I wait for a good quote from them to do that work I ran into a new question!! At some point a conversion was put on the car that replaced the stock 4 lug set up (for the wheels) to five lugs.. Also I believe new drum pads were put on and drums. I was researching switching the drums to disc brakes and I read that if the spindles were converted to v-8/five lug spindles then that could cause some steering issues (since it is a 6cyl??)? Is there a way to pull off the tire and check/investigate the spindle to find out what someone had put on there??
Thanks guys!
Old Mar 3, 2014 | 06:52 PM
skip3535's Avatar
skip3535
I guess the best way would be to find out if The bearings are the same. if not then they probably changed the spindles. The drum and hub are pressed together. I think the 6cyl also has a smaller drum than the v8
Old Mar 4, 2014 | 06:45 AM
Al Newman's Avatar
Al Newman
Simply changing spindles and leaving the steering linkage stock 6 cylinder is a bad idea. Replace idler arm, tie rods, pitman arm, and center link to V8 stuff will be okay.
Best,
Al
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
winner99
Sep 30, 2015 07:04 PM
labudski
Aug 24, 2015 07:23 AM
Pain.
Aug 7, 2015 10:48 PM
eZ
Jul 13, 2005 12:53 AM
