Removing the radiator?
Old Mar 16, 2014 | 12:45 PM
5window's Avatar
5window
Default Removing the radiator?
I have recently acquired a '65 6 cylinder/auto Mustang coupe. Looks like I am going to need to radiator repair and there's a good shop nearby. I am looking for tips on how best to remove the radiator, block of the transmission cooler lines and not lose all of my transmission fluid in the process. I figure I may as well drain and discard all the antifreeze as I'll have the radiator cleaned while being repaired ( it leaks across the top of the tank on the engine side.)
Thanks for the help.
Old Mar 16, 2014 | 01:27 PM
Boogie's_AutoRama's Avatar
Boogie's_AutoRama
Slip a piece of hose over both ends of the transmission lines.
Although, you won't loose that much fluid if you just let it drip.
When we're doing a radiator swap here at the shop, we never block the trans lines and rarely lose more than a cup of fluid.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
