I want to pull my engine.
Old Oct 15, 2005 | 09:55 PM
tylerdru's Avatar
tylerdru
Default I want to pull my engine.
I know just about everything i need to do to pull the engine. Is un hooking the tranny just like 6 bolts? and what part of the engine do i hook the lift to? I want to pull it so i can repaint the engine bay and do some work on the engine.
Old Oct 16, 2005 | 12:04 AM
Scott H.'s Avatar
Scott H.
Default RE: I want to pull my engine.
If you have an automatic then you have the torque converter bolts to remove as well. They can be accessed by removing the inspection plate that is bolted to the block plate at the bottom of the bell housing. If you have a standard transmission, it is easier to set a transmission jack under the transmission, disconect the bell housing, drive shaft and linkage then roll it straight back. Make sure your engine hoist is hooked up and suporting the weight at the rear of the engine.
Don't forget to support the front of the automatic transmission/bellhousing on blocks, or a mechanically operated transmission jack.
As for lifting out, I prefer using a carburetor base lifting plate with studs in the manifold, or if that is not available, bolting plates to the oposite corners of the intake manifold that have large holes for inserting hooks, and using a jack screw balance bar.
Good luck, and be careful!
Old Oct 18, 2005 | 01:15 AM
Silver Ponys's Avatar
Silver Ponys
I hooked mine up to the bolt holes in the end of the heads. Be careful and make sure your hoist is in good shape
[IMG]local://upfiles/22931/87687F1D5B4D493CB567347224143FE1.jpg[/IMG]
Old Oct 18, 2005 | 04:57 AM
Soaring's Avatar
Soaring
I ♥ Acer
Why not just pull the engine and tranny together as one unit?
Old Oct 18, 2005 | 08:04 AM
lClutchl's Avatar
lClutchl
I always use the bolts at the end of the heads as well. For some reason I just don't trust a 7/16 bolt running into aluminum to hold a 500lb engine.
Old Oct 18, 2005 | 10:11 AM
garywwelch's Avatar
garywwelch
Tyler,
I found that the use of an engine leveler helps as well. It has 4 chains attached to a bar that attaches to hoist. THe bar has a threaded rod that allows you to tilt the engine.
Gary
66 Fastback
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
jrrhd73must
Oct 2, 2015 09:17 PM
