front suspension
No Carl. That is not necessary. Here is what parts you need if you are doing the Granada brake swap. This parts list was taken off the FAQ section above. Go there to get more info.
· Spindles (everything from spindle out)
· Rotors (may be reusable)
· Calipers, can use as cores or rebuild (Appendix A)
· Dust shields
· Brake Hoses
· Caliper Hardware
· Bearings (may reuse, but why?)
· Both outer tie rods
· Both adjusting sleeves
· Brake hose to frame mounting hardware (may not need)
· Brake proportioning valve (also called brake fluid distribution block)
· Master Cylinder (rebuild or use as core)
· Dust shields
· Brake Hoses
· Caliper Hardware
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
