Heater core
Old Sep 22, 2014 | 10:03 PM
panelguy's Avatar
panelguy
Default Heater core
Hello, I searched for info on changing the heater core in a 69 Mustang but couldn't find any threads. Anyone know where it might br in this forum?
Thanks
Old Sep 23, 2014 | 08:57 AM
panelguy's Avatar
panelguy
Or if you have changed a heater core how did it go, I understand the whole dash must be removed.
This 69 doesn't have air conditioning if that makes a difference.
Thanks
Old Sep 23, 2014 | 02:20 PM
88 orangepeel notch's Avatar
88 orangepeel notch
You won't get many replies in this forum for your question. I'd start a new thread down in the Classic Mustang Tech section. They'll get you started, good luck in the repair.
And welcome to the forum.
Old Sep 27, 2014 | 10:34 PM
99GTvert's Avatar
99GTvert
is my username.
Moving to tech..
Old Sep 27, 2014 | 11:41 PM
Mustangdemon67's Avatar
Mustangdemon67
It's no big deal. You don't need to remove the dash, just the glove box. You 'll be down on the floor alot, it gets a little tight under there. Drain the radiator, check the condition of the rubber heater hoses also . It's pretty straight forward, buy the heater box rebuild kit also, it's just a package of rubber and foam but it helps seal up the box pretty good.
Old Sep 28, 2014 | 07:48 AM
panelguy's Avatar
panelguy
Thanks all.
Old Sep 28, 2014 | 08:48 AM
groho's Avatar
groho
Pay attention to the hose routing too, the heater core acts as a secondary radiator.
Old Sep 28, 2014 | 05:22 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
also make sure to not put tap water in your cooling system. buy a gallon of unmixed coolant and a gallon of distilled water(its cheaper than pay for the premixed 50/50 )
Old Sep 30, 2014 | 02:11 PM
69mach1377's Avatar
69mach1377
IIRC, I had to loosen the right side of the dash for better access.
djbigskrilla
Sep 20, 2022 01:04 AM
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
Calizic
Aug 28, 2015 01:46 PM
Mnuckolls
Aug 9, 2015 08:54 AM
