1966 Fastback Bouncy Front end ??
Old Oct 21, 2014 | 06:51 PM
1966fastbach's Avatar
1966fastbach
Default 1966 Fastback Bouncy Front end ??
I have a 1966 Fastback. Shelby drop,new roller spring perches and cut about 3 inches off the front springs. it actually drives really nice and front end alignment is spot on. tires wear normal. my problem is if i'm driving down the road over 20 or 30 miles per hour and i hit a decent bump or drop in the road especially if it is during a slight turn the whole front end starts bouncing and wobbling. once i hit the brakes a little it smooths right out again. everything looks tight underneath. at a loss !!!! anybody have any ideas ???
Old Oct 22, 2014 | 07:17 AM
barnett468's Avatar
barnett468
hello;
more info would be helpful
of you hit a speed bump etc and the front end bounces like there is no shocks, yiu need new or better shocks.
if you try to push down on the front and it only moves an 1 inch, it is likely way too stiff which can contribute to the type of problem you are describing.
all the suspension must be in good shape., it your tie rods are worn it can do some of this, if your idler arm is worn it can do some if this etc.
if your inner lower suspension arm bushings are bad it will do some of this.
Old Oct 22, 2014 | 03:47 PM
67mustang302's Avatar
67mustang302
Shocks also need to be matched to springs. So if you cut the coils you've increased spring rate, and with a shock that's too soft it may not be able to effectively dampen the motion.
Old Oct 23, 2014 | 02:30 AM
barnett468's Avatar
barnett468
This is where its nice to have shocks that have individually adjustable compression and rebound. The stiffer the spring, the more rebound damping it takes to control bounce. Excessive rebound will cause "packing" over successive bumps. This is where suspension returns less far over each consecutive bump which reduces travel.
. . . . . . . . . . . . . 64 - 73 mustang
http://www.strangeengineering.net/ma...re=default&p=2
Old Oct 23, 2014 | 05:45 AM
LynnBob Mustang's Avatar
LynnBob Mustang
Cutting 3 inches off the springs seems excessive. I would go with the proper drop springs.
Lynn
Old Oct 23, 2014 | 10:21 AM
Starfury's Avatar
Starfury
I'm assuming he means 3" around the coil, not a vertical 3". 3" around a coil is roughly 1/4-coil and makes much more sense.
Barnett, those are some pretty badass shocks...but holy crap, $1000 for a set? At that price, you better be racing with it. Maier Racing's Bilstein shocks are custom valved and cost half that, iirc, and I bet most people would be more than happy with them.
Old Oct 23, 2014 | 11:16 AM
barnett468's Avatar
barnett468
hey...how are ya, where ya been?
yeah the strange shocks are kinda fancy and so is their price, but hey, they're shiny and the bilsteins aren't, lol.
Old Oct 23, 2014 | 02:03 PM
Starfury's Avatar
Starfury
School. Last year of BA @ UC Davis. Taking quite a bit of time...
Old Oct 23, 2014 | 05:33 PM
67mustang302
The custom valved Bilsteins from Maier are the "old" non adjustable shocks. The new (and better) JRI shocks are hellaciously expensive. It's basically equivalent to a Penske, which are also crazy expensive.
The Bilsteins are really good, and the JRI are absolute top of the line. You're not going to find better than a JRI/Penske etc without converting to an electromagnetic shock system.
$300 per shock with fixed valving, $750 for a single adjustable, and $1,250 for double adjustable. Per shock, for the front...rear shocks are cheaper. But a full set of double adjustable JRI is about $4,000. Penske's are in the same ballpark, astronomical.
Old Oct 23, 2014 | 08:13 PM
1966fastbach
I should have been more clear. When i was going for the right height i would cut 1" of length at a time off the new stock spring and then reassemble and drive a while and then do it again. total of 3" was cut off the coils. yes it was a pain in the butt but i had a great spring compressor that helped alot.
poke68
Dec 16, 2025 03:36 PM
the5
Sep 19, 2015 06:13 PM
Sep 10, 2015 08:39 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
