T10 question shifter loose
Old Mar 24, 2015 | 09:59 PM
barnett468's Avatar
barnett468
Originally Posted by 66_grn_fstbk
Will do. It seems simple enough... i mean what could possibly go wrong.. its not like starting a small project like this has any chance of snowballing into something major!
Old Mar 25, 2015 | 08:55 AM
Starfury's Avatar
Starfury
Barnett, we're talking about different bushings.
The bushings that are part of the shifter rebuild kit are not at all something you can get from a hardware store. They're small cylindrical things with a half-dome top, with a spring that sits under each one. They fit inside the shifter assembly. These are the bushings causing the slop in his shifter.
I believe the bushings you're referring to are the shifter linkage bushings. And while yes, some bolts and washers would do the trick, I'd really recommend a set of Hurst/Mr Gasket (they're the same parent company, and the same parts) metal shift bushings/pins. Along with some lithium grease, they really do take up most of the linkage slack, and the handy pins they come with won't come off.
Old Mar 25, 2015 | 02:56 PM
barnett468's Avatar
barnett468
ahhh. . . ok, there is a metal cup and spring on each side of the shifter . . they are trapped by the housing . . unbolt the shifter while holding it in place . . slowly lift shifter up and trap the cups when they are exposed . . remove shifter the rest of the way . . if the cups do not fall out after you release them they are simply gummed up . . spray contact cleaner in them then push, pull, pry, etc until the come out . . these rarely need replacing because they do not wear out . . they usually just need cleaning and re-greasing but your rubber bushings are probably wasted which is why i suggested washers on the bolts and not using the rubber bushings.
if you have the 65 type cups, they use rubber instead of springs and these will be bad.
Old Mar 25, 2015 | 06:44 PM
66_grn_fstbk's Avatar
66_grn_fstbk
Well I have ordered everything I think I need. The bits shall arrive tomorrow.. And then saturday morning I shall begin. Its just two bolts... shouldnt take me but 48 hrs of cussing to get it done!
Thanks for the advice.
cheers
Old Mar 26, 2015 | 02:20 PM
barnett468's Avatar
barnett468
cheers
ok but you shouldn't need anything except the 4 washers i suggested . . the spring loaded cups never wear out . . if you use the factory rubber biushings on the bolts, your shifter will still be sloppy . . i have only repaired around 100 of these.
Old Mar 26, 2015 | 08:10 PM
Starfury's Avatar
Starfury
Barnett, that's not always true. The bushing cups on my old factory shifter were toast. The tops were mashed slightly flat, and they were mushroomed out and jammed in the shifter housing. I've seen others the same way. 50 years of abuse can do funny things. In addition, as the cups get jammed into their housings, the springs are in a constant compressed state and can wear out. The kit is like $10, and the time to clean the gunk off of questionable cups and springs is worth more to me than that.
Old Mar 26, 2015 | 09:05 PM
66_grn_fstbk
Well saturday we shall see what it looks like. Shouldnt be hard, and doin it right the first time will be ok for me.
thanks for your help.
cheers
Old Mar 26, 2015 | 09:29 PM
barnett468's Avatar
barnett468
yeah the 10.00 isnt much.
Old Mar 26, 2015 | 09:32 PM
barnett468's Avatar
barnett468
wow, yours was certainly beat to hell . . i have never "had" to replace them in any shifter, but i have on some just because, and yes, the new springs are sometimes stiffer than the old ones.
carid
Jul 8, 2016 09:55 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
vintageaion
Sep 8, 2015 10:45 AM
Webster454
Sep 7, 2015 04:59 AM
