Adjustable engine mounts
Old Mar 23, 2015 | 07:35 PM
dcohen's Avatar
dcohen
Default Adjustable engine mounts
Hi all,
I have been looking at the Ron Morris adjustable motor mounts for my 1966 mustang. Specifically the 1/2" lowering mounts. I need a little more clearance for the transmission. Lowering the engine would give me the clearance I need as well as improve my driveline angle.
I have read that the 66 mustang engine mounts were 1/2" higher than the 65 mounts. If that is the case then the 1/2" lowering mounts might actually result in the engine being lowered 1". Does anybody know the correct story on this?
My other question is about my clutch linkage. I have the factory Z bar linkage. If I use the lowering mounts, what will have to be done to make the linkage work?
Here are the mounts I am referring to.
http://www.cjponyparts.com/ron-morri...970/p/MM6110L/
Old Mar 24, 2015 | 03:44 AM
tx65coupe's Avatar
tx65coupe
I have the RMP adjustable mounts and have been very happy with them, but I can't answer your question about the lowering mounts. I do know that with the clearance I have between the stock style replacement oil pan and the crossmember, I can't go much lower.
Old Mar 24, 2015 | 10:22 AM
69mach1377's Avatar
69mach1377
Can you compare the two mounts side by side?
Old Mar 24, 2015 | 06:44 PM
dcohen's Avatar
dcohen
The stock mounts vs the ron morris mounts or the two different height option ron morris mounts?
Old Mar 25, 2015 | 10:24 AM
69mach1377's Avatar
69mach1377
66 vs. 65 stock mounts...are they really different?
Old Mar 26, 2015 | 05:08 AM
tx65coupe's Avatar
tx65coupe
The early 65 and 66 mounts are different, but have no idea about the height.
Old Mar 26, 2015 | 05:29 PM
dcohen's Avatar
dcohen
ok, assuming that the 1/2" lowering mounts only lower the engine 1/2" does anybody have any thoughts on how this would affect the clutch linkage?
Nick Oliver
Oct 17, 2018 04:22 AM
StalkerGT
Sep 25, 2015 02:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
RWHEELS
Sep 5, 2015 03:42 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
