Need help with accelerator issue.
Old Jun 25, 2015 | 07:18 PM
wdehm's Avatar
wdehm
Default Need help with accelerator issue.
I have completed all of the modifications to the intake manifold to convert from a 1bbl to a 2bbl carburetor. Had to mount the Holley 2300 carburetor sideways due to valve cover clearance issues. When I press the accelerator pedal the rod pushes up instead of down. Does anybody have any ideas that would work? I want to drive it again.
Old Jun 26, 2015 | 08:13 PM
barnett468's Avatar
barnett468
your post makes no sense . . if you mount a carb sideways on an intake with a divided plenum it probably wont even run because only 4 cylinders are getting fuel.
Old Jun 27, 2015 | 10:20 AM
wdehm's Avatar
wdehm
Thanks for the supply. I should have said that my engine is an inline six. Mounted as it is the car does run very well. Just need some ideas to either modify the rod coming off the bell housing or replacing the set up from the accelerator to the carb.
Old Jun 27, 2015 | 10:21 AM
wdehm's Avatar
wdehm
Thanks for the supply. I should have said that my engine is an inline six and there is no divided plenum. Mounted as it is the car does run very well. Just need some ideas to either modify the rod coming off the bell housing or replacing the set up from the accelerator to the carb.
Old Jun 27, 2015 | 11:36 PM
barnett468's Avatar
barnett468
lol, ok, thats a different animal.
post some good photos of it so we can see what we are dealing with.
Thunderball
15
Nov 22, 2015 11:49 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Bokeo
Oct 10, 2015 08:28 PM
Offendant
Sep 23, 2015 07:21 PM
zanemoseley
Sep 6, 2015 12:58 PM
