Carb flooding
Old Dec 22, 2015 | 11:14 AM
Cbonis72's Avatar
Cbonis72
Default Carb flooding
Have a 1972 mustang, just rebuilt 302 with new everything gas pump included and 2100 2V Autolite carb. Drove it a little ran well but capsule always smell gas and went through a lot fast. then it started to flood out, now won't start. Here is what I checked
1) Checked voltage regulator
2) Ck Coil
3 ) Ck distributor to Spark to plugs
All ok
Took gas line off carb used quick start and poured a little gas in started to fire up.
Cranked the car for 2-3 minutes and filled up a gallon jug.
My question is the pump pushing too much gas, or is that normal and the internals of the carb not regulating the flow?
Help?
Old Dec 24, 2015 | 10:23 AM
69mach1377's Avatar
69mach1377
Check your carb's needle and seat for contamination?
Old Dec 27, 2015 | 12:15 PM
MonsterBilly's Avatar
MonsterBilly
rebuild your carb. SOunds like you have gunk in it and the needle is stuck
Old Jan 2, 2016 | 05:23 PM
barnett468's Avatar
barnett468
also, set the float level to 1/2" and install a tiny clear fuel filter after the pump if you have a rubber line, if not, install one before the pump.
65Dream
Dec 19, 2015 11:00 AM
Mustang Videos
Dec 19, 2015 02:37 AM
tmac41784
Dec 17, 2015 07:17 PM
lincolnshibuya
Dec 3, 2015 12:27 PM
Urambo Tauro
Nov 25, 2015 03:02 PM
