HP 358W in and more soon
Old Mar 5, 2016 | 03:31 PM
Mustangs of Illinois's Avatar
Default HP 358W in and more soon
Well the HP358W is in and does it run good ! The 302 I had was okay, but this 358 puts it to shame.
Got the aluminum pulleys on, aluminum radiator with electric fans on.
Have the seats upgraded to a lot more comfortable ones.
In the next few weeks I will be putting a Big ***** Thumper cam in it, electric vacuum pump and chrome canister for the power brakes...
And the new "Mustangs of Illinois" front window logo like the one on my truck...
Then car show time in a few weeks after that, hope to see some of you at some Illinois car shows..
Attached Thumbnails HP 358W in and more soon-12791081_10204357323652313_5458282466350061719_n.jpg   HP 358W in and more soon-12799314_10204357323332305_7385490296400734504_n.jpg   HP 358W in and more soon-12799381_10204357323012297_1325892334641770495_n.jpg   HP 358W in and more soon-20150911_163835.jpg   HP 358W in and more soon-12803287_10204357323932320_4616142011276161905_n.jpg
Old Mar 6, 2016 | 03:27 PM
barnett468's Avatar
barnett468
Why do you want the Thumper cam?
Old Mar 7, 2016 | 03:43 PM
Just for the way it sounds. The cam I have is close to it, but doesn't sound as good. I use to have one in my HP289 and really liked it. Not worried about performance wise, as it is just a driver/show car and not a racer..
Old Mar 7, 2016 | 08:54 PM
Mustangdemon67's Avatar
Mustangdemon67
Looks good 👍
Old Mar 8, 2016 | 06:51 PM
Thanks....It was a California car originally
Old Mar 30, 2016 | 10:53 AM
teeeeg67's Avatar
teeeeg67
Are those the procar seats?
Old Mar 30, 2016 | 03:48 PM
barnett468's Avatar
barnett468
I would do something about that ballast resistor cuz it ain't Kosher.
Old Apr 1, 2016 | 07:23 PM
Yep Pro Car seats. Have not figured out where to relocate it yet (ballast resister)
Old Apr 1, 2016 | 08:32 PM
barnett468's Avatar
barnett468
get rid of the ballast resistor .
Old Apr 2, 2016 | 07:29 AM
I would love to get rid of it. But I was in the understanding that that distributor needed a ballast resistor to supply less voltage to it ? Or has anybody out there had one and never used it ?
It is on because I had found this and talked to Mallory about it..
Before installing the UNILITE ® Distributor, make sure that your vehicle is equipped with an ignition ballast resistor (or loom resistance wire) in the wire between the ignition switch and the coil (+)terminal. Check a service manual for your vehicle to locate the ignition ballast resistor (or loom resistance wire). If your vehicle is not equipped with an ignition ballast resistor, install a Mallory Ignition Ballast Resistor Part No. 700 in the wire between the ignition switch and the coil (+) terminal.
Failure to use an ignition ballast resistor will eventually destroy the UNILITE ® Ignition Module.
Jly154
Jan 4, 2016 12:08 AM
GARY247
Jan 3, 2016 12:26 PM
dkpGTCS
Jan 3, 2016 07:05 AM
bluovalguy
Dec 16, 2015 01:26 PM
