Anyone Recognize This?
Old Mar 31, 2016 | 12:53 PM
carsofchaos's Avatar
carsofchaos
Default Anyone Recognize This?
Hey guys,
On the 67 project I picked up, the original drivetrain (289) was swapped for a 302 drive train out of a 1970 Mustang. One of the mods the previous owner's son did was the distributor, which has (for lack of a better term) and integral ignition coil. The guy I bought it from didn't know much about cars and couldn't tell me what this distributor is. A couple friends have said it's a GM, but weren't sure. I've looked for part numbers but don't see any, other than when I pop the cap off there's a part which says "Wells" on it. Can anyone please identify this?
Thanks,
Keith
carsofchaos
Old Mar 31, 2016 | 02:50 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
It's a GM style HEI distributor. They are actually damned fine distributors but you will burn in hell if you use one on your Ford engine.
Old Mar 31, 2016 | 08:47 PM
barnett468's Avatar
barnett468
that is a factory ford dist . there is likely a p/n and date code on it somewhere but is definitely after 1973.
WELLS is an aftermarket parts supplier so it is meaningless for id purposes.
Old Apr 1, 2016 | 08:55 AM
bop11's Avatar
bop11
There were, are, companies that put GM HEI heads on Ford drives, and having a black cap I would suspect this is one. You can buy similar new for Ford off EBAY but they have red or blue caps and are probably a less quality build as they only cost about $40 to $60. If you get pinging, you may have to reduce the vacuum advance. If it is a GM head, it is probably pretty good quality, but as Fastback said, you may feel some heat.
Old Apr 1, 2016 | 11:00 AM
carsofchaos
Hi Guys,
As always thanks for the help. I had suspected it to be GM as a couple of my buddies said. Yeah.....it being front and center on my Mustang engine probably will not go over too well. If it is a Ford as fastbackford351 says.....that's cool. I think I'm going to have to yank it out to find some part numbers though as I went over it pretty thoroughly and couldn't find any.
This car is by no means original (like I said non stock drive train for starters) so while I'm not concerned about originality I do feel a little errrr about having a GM HEI on my ride.
Old Apr 1, 2016 | 02:28 PM
barnett468's Avatar
barnett468
to be more specific, it is a gm style but it is not a gm distributor that was modified to fit a ford . there are aftermarket distributors just like that for the fords.
Old Apr 1, 2016 | 08:17 PM
fastbackford351
Foghorn Leghorn
^this^
Old Apr 4, 2016 | 10:56 AM
BKKSW's Avatar
BKKSW
There are several just like that on Amazon, for Fords, for roughly $55..
LordRipberger
Jun 18, 2017 06:37 AM
67STANGX2
28
Mar 4, 2016 12:57 PM
sleeper_inc
4 Cylinder General Discussion
Feb 13, 2016 08:08 AM
CDC4.0
Feb 9, 2016 04:43 PM
